turbo screech? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-02-2013, 03:16 PM Thread Starter
Redlightning79's Avatar
Question turbo screech?
I'm new to diesels and this site. I just testdrove a 2000 f350 ext cab flatbed are 6 speed manual 4x4. It drove good until about 2100 rpm then I heard some kind of screeching. Almost like brakes would make but I wasn't touching them at all. It continued to screech until I shifted. Then it stopped until I hit 2100 rpm again. Does anyone know what this is why it does it or if it is bad? 220k all stock. Former fleet truck. Thanks
Redlightning79 is offline
post #2 of 11 Old 09-02-2013, 03:32 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I worked on a truck that did this exact thing. Ended up being the fan clutch was locked up. Shut the truck off and grab the fan and try to rotate it. It should have some resistance but spin fairly easy. If it is like the one I had, you had to pull hard on the fan to rotate it and the noise is where the belt spins on the pulley. It will be very noticeable if that is the issue.
dhanna6powerstroke is offline
post #3 of 11 Old 09-02-2013, 03:38 PM Thread Starter
Thanks! I'll have to go back and take a second look at the truck
post #4 of 11 Old 09-02-2013, 03:43 PM
Mod Newbie
Quoted: 20 Post(s)
Post back what you find
post #5 of 11 Old 09-02-2013, 04:03 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
could be the compressor wheel contacting the housing?
if the fan clutch is a bust, take the intake tube off and take a look at the compressor wheel. if its chunked up and the housing has a wear mark id say you need a turbo rebuild.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 11 Old 09-03-2013, 09:22 AM Thread Starter
Its at a dealership so I asked them to have their diesel mechanic check out the turbo and fan clutch. I just remembered the turbo was covered in soot. Any ideas on that?
post #7 of 11 Old 09-03-2013, 05:55 PM
Mod Newbie
Quoted: 20 Post(s)
Soot or oil residue where the intercooler tubes connect?
post #8 of 11 Old 09-03-2013, 06:14 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
leaking up pipes. mine is doing the same thing when the turbo builds boost. sounds just like what youre describing.
get under the truck and look up to where the manifolds go up towards the turbo. if you shine a flashlight from driver side up, you will probably see soot around the flanges.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #9 of 11 Old 09-03-2013, 06:23 PM
Quoted: 283 Post(s)
id say soot or oil.
the ccv being drawn into the system really gets everything dirty.
and leaking up pipes do make a black mess.
post #10 of 11 Old 09-03-2013, 06:27 PM Thread Starter
They said the fan clutch is stuck on which explains the noise and as for leaking up pipes, is that a matter of tightening connections or something more serious?
Tags
screech , troubleshoot , turbo 7.3 powerstoke
