7.3 shut down need help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-27-2013, 04:39 AM Thread Starter
I was heading down the road and engine just shut down, now engine will turn over but will not start. I can spray engine starter in breather and engine will fire and shut right back down. I have checked filter housing and the fuel is getting there so i'm thinking fuel pump is working. Any ideas what maybe wrong with this. Truck is a 1999 f350 7.3 thanks
vester1426 is offline
post #2 of 5 Old 07-27-2013, 04:55 AM
sldghamr's Avatar
have you change the cam sensor? known problem w/ the 7.3's
check fuses
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #3 of 5 Old 07-27-2013, 05:05 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
check oil level , possibly cam sensor , check all fuses , in all seriousness , really need to get it on a scanner and see what codes are in it and monitor data to see what it doesn't have that it needs , there is a list of things it could be , and the worst thing to do is start throwing parts at it , besides maybe a cam sensor
ITS STOCK
SCUFFY828 is offline
post #4 of 5 Old 07-27-2013, 07:43 AM
Quoted: 904 Post(s)
Feedback Score: 3 reviews
For the love of our rides, can there please be a sticky on the main page or something for people to see links of engine damage from using starting fluid.
Don't ever use starting fluid. If you feel the need to use something similar then use WD40 or some other type of penetrating oil. Never ever ether.
Anyway check fuse #30 under the dash. I think that's the one for the IDM/fuel bowl heater.
Corey@CNCFAB is offline
post #5 of 5 Old 07-27-2013, 08:00 AM Thread Starter
I have checked oil level and fuel pump, Hpop, and found nothing. I went out this morning truck fired up and ran for bout 1min. then just like the switch was turned off shut down and will not fire again.
