Ran out of gas...now 1 injector acting stuck - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-13-2013, 06:46 PM Thread Starter
208_stroker's Avatar
Ok fellow stroker fans,
I ran out of gas (stupid I know) while returning home from a job interview. I had my roommate come and tow me to a station and I put in 20. She fired up, but immediately started missing on 2-3 cylinders. After about 30 sec she leveled out, but it seems like 1 injector is still stuck.
Is there any advice to resolve this issue or am I going to have to order new injectors? I could really use some help here before I go ape ****...
208_stroker is offline
post #2 of 5 Old 07-13-2013, 08:27 PM
goats's Avatar
Quoted: 2 Post(s)
You may have air in the line still
goats is offline
post #3 of 5 Old 07-13-2013, 08:35 PM Thread Starter
I was doing a little reading and I guess there is a bleeder valve for your injectors? Is that the proper way to do it or should I just let her idle for a couple minutes to allow the air to be pushed from the lines?
post #4 of 5 Old 07-13-2013, 08:54 PM
I'm trying to figure out why you had "gas" in the truck at all.
2006 White F350 CCLB 2WD
dowmace is offline
post #5 of 5 Old 07-13-2013, 08:58 PM Thread Starter
Yeah...figured I run a little E85 through her to see if I could get a little more top end for that 2-3 gear stretch...
I was referring to diesel fuel. My lingo is lacking....
