Powerstroke 7.3 2001 mod garrett GTP38R upgrade having issues - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-10-2013, 05:26 PM Thread Starter
Hi all !
On the weekend I installed a new garrett GTP38R turbo and banks power elbow and 4" SS ( Diamond eye ) straight through system on my truck.
Its not running the best and seams to have a slight miss.
Its coming up with the following codes..
P0476- Exhaust pressure control valve perform
P0269- Cyl 3 Contribution/ balance fault
P0284- Cyl 8 Contribution/ balance fault
P1293- High Side open bank 1 ( Right )
P1294- High Side open bank 2 ( Left )
Anyone had troubles with mounting these elbow hitting the firewall ? ( I dont think its hitting but damm sounds like it .
Its making a loud drumming noise in the cab, little oil leaks also after install. looks like its coming out of the rod on the turbo pedestal. I left it pushed all the way in like the instructions said ?
Your help will be greatly appreciated !!
timthev8man is offline
post #2 of 4 Old 07-10-2013, 06:28 PM
If I were you I'd go over all your wire harnesses and make sure that's all straight and tight. Are you running stock tuning?
Moto2four is offline
post #3 of 4 Old 07-10-2013, 06:43 PM Thread Starter
Ok,
I'm running a DP tuner
post #4 of 4 Old 07-10-2013, 09:57 PM Thread Starter
I cleared both high side open banks faults . They were stored while I cranked it without injector pulse to prime turbo with oil before starting . Seams to be mainly the exhaust pressure control valve perform issue
