no hot start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-05-2013, 12:40 PM Thread Starter
no hot start
hi I am new here and need a little advice, I got 95 f350 7.3 and it starts fine when cold but after it warms up no hit, I change the lift pump because it was leaking at the wep hole thinking that would fix it. it didn't, new fuel filter, cannot get my scanner to pull any codes, no data link. checked fuses,okthe truck had been running great until now.could use all the help I can get.
michaellee74044 is offline
post #2 of 5 Old 07-09-2013, 12:21 PM
excuse my ignorance to diesel as I am a new owner, but do these have a CPS (crank position sensor). If so I would check that as it would cause a gasser to start ok cold (circuit contacts shrink) and not start warm (circuit contacts separate when warm)
Seattle60 is offline
post #3 of 5 Old 07-09-2013, 03:06 PM
countryraised's Avatar
first off most scanners will not do much for the 7.3 diesels, you need something like auto enginuity to actually read whats going on. I would bet on it being the IPR or sensor (on back of high pressure pump) not working after heat soaked.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #4 of 5 Old 07-11-2013, 01:54 PM Thread Starter
i changed the cam sensor and it didn't helped.
post #5 of 5 Old 07-11-2013, 01:57 PM Thread Starter
I also changed the pressure switch on the left head and still no hot start, i'll change the irp on hpop next, thanks for the help.
