ShoW & TeLL Guess where this oil leak is? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-07-2013, 09:47 PM Thread Starter
racerx250's Avatar
Buds, Looking into a 04 cc Dually Dealer wont drop price just yet. But when I looked under THis is what I saw. I know its a long shot but where do you think its coming from? You guys know this 6.0 inside out... Thanks
ID:	108361   Click image for larger version
ID:	108369   Click image for larger version
ID:	108377   Click image for larger version
ID:	108385   Click image for larger version
Sold my F250 1997 7.3L Bone Stock
Now between 6.0
7.3
racerx250 is offline
post #2 of 4 Old 07-09-2013, 11:27 AM
I think the only way to get a better idea is to degrease the trans pan area and oil pan area. Once clean drive it a bit and see if you can see any drips. Just to give you an idea, I just bought a 6.0 truck from a dealer that looked about the same as yours, oil mess wise. I took it home for the night, sprayed it off with purple power, drove it around when it was clean and saw NO leaks 'knock on wood'. So it could have been an old part that was leaking then replaced and not cleaned properly. my 2 cents. hope that helps.
Seattle60 is offline
post #3 of 4 Old 07-09-2013, 02:03 PM
countryraised's Avatar
I agree it should be cleaned for a good diagnosis, but I would suspect it is coming from up around the high pressure oil pump. it is mounted on top of the engine in the back of the valley on those engines.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #4 of 4 Old 07-22-2013, 07:36 PM
Mine looked similar when I bought, it was coming from the passenger valve cover
lupe.r is offline
