White smoke after coolant pressure test - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-27-2013, 09:17 AM Thread Starter
I have the same problem so many others have with my 2005 6.0 puking coolant ocassionally. I have searched for my specific issue but haven't found it on the forums so figured I would ask.
Every once in a while I get a little coolant puking from the degass bottle. Never gets very low on coolant, I usually add only about 1/3 to 1/2 gallon of Zerex G05 when I notce it is low which has been 3 times over 6 months. I have replaced the degass bottle cap with a FOMOCO and it still did it the other day, not pulling anything, just town driving.
A mechanic told me to get a coolant pressure test kit so I borrowed one and tested the cap first and it held to 16Psi. I then pressurized the system at the degass bottle to around 16-17 Psi, jacked up the rear end about 8" and removed the EGR valve. I let it is for 2.5 hours. I never saw any coolant at the EGR valve port like I expected and I never lost pressure on the tester; it was still at 16-17. The next morning when I started it, it started rough and blew white smoke out. This is not normal, I have never seen it blow white smoke out before. It smoked for only a few seconds and I have started and drove it a few times since and it never smoked again.
Anyone know why it would smoke like that?
Also, I just bought an Edge programmer to monitor the ECT and EOT. I drove it about 15 miles and the warmest it ever got was ECT 203 deg and EOT 208. They were almost always within 2-4 deg apart while driving for about 1/2 hour.
Thanks for any advice.
tsimpsonaz is offline
post #2 of 11 Old 04-27-2013, 10:01 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I know you don't want to hear this but this symptoms are sounding like a blown hg. Mine did the same thing but it got to the point when I went to start the engine it was acting like it was hydro locked. The coolant system should stay very low in pressure if you are at 16 all the time either you have a blown egr cooler or blown hg. Tuscany has a great post on how to diagnose a blown head gasket or you can you tube hg test. Good luck
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 11 Old 04-27-2013, 01:10 PM Thread Starter
Thanks for the info, but to clarify it isn't at 16 all the time, it was at 16 psi when I pumped it up with a coolant pressure tester to 16 psi. I was just stating that it stayed at the 16 during my two hour test. The engine was never started, it was just sitting there.
post #4 of 11 Old 04-27-2013, 04:28 PM
Ok. I would still check your coolant pressure. To me pressurizing the system would only check for leaks. The reason I say that is when my Hgs were blown my coolant pressure never went below 16, I would remove the coolant cap to relieve pressure and it would build pressure in no time (with the engine running). I would say an injector but the smoke would smell like diesel. Do you have any codes? Could be a bad egr valve but like I said check out Tuscany, he bought a set up at tsc cheap to test coolant pressure. This will give you a definite answer. Good luck
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #5 of 11 Old 04-30-2013, 08:32 PM Thread Starter
I watched the video from Tuscany and plan to make that test guage. Thanks!
post #6 of 11 Old 05-01-2013, 01:11 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 274 Post(s)
This may be off topic but... I started a thread elsewhere but have gotten no response..... Are you adding the G-05 right on top of the ford Gold, or have you switched completely over to G-05? Is it acceptable to put G-05 on top of Ford Gold? or is it, use one or the either, dont mix?
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #7 of 11 Old 05-01-2013, 01:26 PM
wach your oil and coolant temp gauage, pull a decent size hill while staying in it the whole way let me know what the temp is then, try to keep as much boost up as poss
Modern Diesel Performance is offline
post #8 of 11 Old 05-01-2013, 02:19 PM Thread Starter
I have been topping it off with G-05. I am like the 3rd owner of this truck so I am not really sure if it still has the Ford Gold in it or not. I am thinking of draining and refilling. I would like to flush it but hear lots of bad stories of flushing then clogging the oil cooler (aka coolant filter).
post #9 of 11 Old 05-01-2013, 02:26 PM Thread Starter
I will try it. Unfortunately I don't have any good hills to climb unless I hang my fiver on the back and drag it around for a few miles.
I will let you know what the results are.
post #10 of 11 Old 05-04-2013, 09:12 AM Thread Starter
Update. I installed a coolant pressure guage (0-30psi) and drove it for about 40 minutes this morning. I dont have any long hills near me but had to make a dump run so had my 18ft utility trailer and got on it several times with boost up to 25. About 15 minutes of driving EOT was about 190 and ECT was about the same. Coolant pressure was at about 12. After about 40 minutes of driving except for dump stop i was about home and by that time EOT and ECT were about 200. They never were more than 4-5 deg apart. Coolant pressure was then around 16-17 but i didnt get coolant puke. When i would get on it with 25 psi boost the coolant temp would rise by about 1 then would slowly fall back.
I also used one of those liquid combustion leak testers and it did not detect any exhaust gases in the coolant.
Is this pointing to head issues?
