Powertrain clunking - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-25-2013, 11:55 AM Thread Starter
Powertrain clunking
03 F250, If i get on the throttle too fast i hear a "clunk" sound. Pretty sure it is in the drive shaft maybe the U joints. Only makes this noise when i get into the throttle too fast, if i ease in it has no problem. Any suggestions? thanks
xXElaminatorXx is offline
post #2 of 6 Old 04-25-2013, 12:06 PM
nohsp4u's Avatar
As my mechanic would tell me...don't get on it, problem fixed.
So, now that I no longer go to that , I would check the rear diff. Look for leaks at the pinion while you are checking the drive shaft. Lift the back, in neutral and turn the shaft looking for play.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #3 of 6 Old 04-25-2013, 12:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
sounds like axle wrap to me
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 04-29-2013, 08:23 PM
One of the best tests to determine if it us U-joints is this:
When at highway speeds, when you get to the "neutral zone" between pulling and coasting, (similar to cresting a hill) is there a vibration or rumble? Mine was loud enough to make me think I had off road tire treads.
Vibration would be felt more in the seat than on the steering wheel.
prheitz is offline
post #5 of 6 Old 05-10-2013, 10:05 PM Thread Starter
Turned out to be a U joint! Prheitz I did have the rumble too, turned out being the ball joints.
post #6 of 6 Old 05-11-2013, 06:37 PM
Congrats that is was on the lower expense area, there is a lot of satisfaction in eliminating the irritations and having a smooth running vehicle.
prheitz is offline
