03 6.0 no power tried almost every thing. help. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-20-2013, 08:08 AM Thread Starter
alright 2003 6.0 f250. 150000ish miles. ive had problems for the past year i.e. missing, white blueish smoke, real lack of power and gitty up. ive run tests with auto ingenuity which didnt really show anything wrong. buzz tested the injectors and they all checked out. heres what ive replaced: FICM, TPS twice, upgraded egr cooler, flushed the oil cooler, cleaned egr valve, changed intake manifold gaskets. the latest was the egr cooler and the lack of power has actually gotten worse since i did it. i cant afford to have a dealership rape me on repairs and im getting tired of dumping money into maybe's all for no good. so any body who has gone through this and actually ended up figuring it out, please help, other wise my next investment will be c4 to blow it up with.
chris1221 is offline
post #2 of 5 Old 04-20-2013, 08:15 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 896 Post(s)
Feedback Score: 6 reviews
Did the AE pull any codes?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 5 Old 04-20-2013, 08:31 AM Thread Starter
it pulled a bunch of weird codes at first, then we cleared it and none of them came back. it has thrown codes for the throttle position a couple of times and ive changed it twice never to fix the problem i was having.
post #4 of 5 Old 04-21-2013, 04:09 PM Thread Starter
figured it out. vacuum hose to the MAP sensor and blown off.
post #5 of 5 Old 04-22-2013, 06:22 AM
RIP Cam!
Quoted: 896 Post(s)
Good to hear you got it figured out.
