06 6.0 hard starts - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-18-2013, 05:54 AM Thread Starter
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 488 Post(s)
06 6.0 hard starts
We got a 6.0 that hard starts if its not plugged in even in warm weather. It will spin over an inordinate amount of time before if finally fires. When it does fire it runs rough and has no power until the engine warms up. Plug the block in and it runs a little better. The voltages on the FICM are correct. My theory is a battery not performing up to spec, but both test fine. Anyone got any ideas?
starcommtrey1 is offline
post #2 of 16 Old 04-18-2013, 06:15 AM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
Also, after the first fire it will fire up perfect like clockwork. Its only the first fire in the morning.
post #3 of 16 Old 04-19-2013, 08:56 AM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
quick bump
post #4 of 16 Old 04-19-2013, 09:17 AM
Korx's Avatar
No Codes? Sounds like my truck when I had 3 bad glow plugs, but I had codes for those.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #5 of 16 Old 04-19-2013, 04:43 PM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
No, no codes. Like I said, its just when it first fires. Turn it off and it will fire right back up.
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #6 of 16 Old 04-19-2013, 05:41 PM
Term3's Avatar
Possibly a HP oil leak
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #7 of 16 Old 04-19-2013, 06:03 PM
Check standpipes and dummy plugs u defintley have a hpop leak that is bleeding off overnight .....see it all the time
cuttingedgediesel is offline
post #8 of 16 Old 04-21-2013, 05:47 PM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
What is HPOP?
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #9 of 16 Old 04-21-2013, 05:52 PM
High pressure oil pump
post #10 of 16 Old 05-10-2013, 10:21 PM
My 03 was doing this EXACT thing, it turned out to be FICM however. Before i knew it was the FICM i replaced both batteries and fuel filter that cleared up the problem completely until the FICM sat too long without starting. I don't think replacing the batteries and fuel filer would be a bad idea.
xXElaminatorXx is offline
