rf interference - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-02-2013, 04:15 PM Thread Starter
rf interference
I have a 01 7.3 that runs bad only in a 5 block area. there is a radio station and a steel yard with a high power broadcast system. I think we have a rf problem. has anyone heard of such a thing? thanks
1oldford is offline
post #2 of 5 Old 04-03-2013, 07:11 PM
WEWILLE's Avatar
Possibly interfering with cmp signal. I'm assuming you have had the cmp sensor recall performed? If so may want to wrap cmp wires with flexible metal conduit and ground the conduit to the block. Or the easiest solution is to avoid the area!
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #3 of 5 Old 06-02-2013, 05:41 AM
mtmc's Avatar
Yes I've had this problem since I bought my truck. Friday I had to limp past an ambulance because it almost shut my truck down. See the links below:
Jerking from Torque Converter, Overdrive, or Cruise Control?
Radio Frequency Interference (RFI) - Ford Truck Enthusiasts Forums
Consistent Flutter/Stutter Compressor Surge at 60 MPH? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Truck killing issue...Need help. - Ford Truck Enthusiasts Forums
2002 F250 CCSB True Blue L2
5" Turbo Back MBRP, 7" Tip Muffler Delete Spectre CAI Foil Delete Edge Evolution II Glowshift Gauges Hutch/Harpoon Mod Leveled 285/75 Cooper AT3 16x8 Dick Cepek DC2 Mile Marker 449SS Goodmark 2" Steel Cowl SS Step Bars
mtmc is offline
post #4 of 5 Old 06-02-2013, 05:47 AM
mtmc's Avatar
Link to the recall? I ran the VIN for my '02 and didn't find one.
mtmc is offline
post #5 of 5 Old 08-27-2013, 04:24 PM
mtmc's Avatar
Just a quick update. I saw on facebook where a guy was having problems with a CB radio causing interference. Someone suggested unplugging the ICP sensor and trying it. So I figured I'd try it to see if it fixed my radio tower interference problem. It worked! Plugged in, the truck spit and sputtered and even shut off if I was close enough to the tower. Unplugged I had no problems what so ever. I noticed it had a new ICP installed when I got my truck so I assume the previous owner used a cheapo parts store ICP. I'm going to get an ICP from the Ford Dealership and hopefully it will take care of it for good.
mtmc is offline
