2005 6.0 Powerstroke YARD ORNAMENT!!! - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-13-2013, 09:08 AM Thread Starter
I have a 2005 F350 Superduty Powerstroke 6.0 Diesel with just now 50,000 miles on it. Started it and put into drive and it died as though it ran out of fuel (Had a full tank) It cranks but would not start again so I ran codes and got the following: 261, 264, 267, 270, 276, 279, 282, 336, 403, 405, 611, 673, 2614 and 2617. Batteries are good, checked wires for obvious problems, does not smoke while cranking. I have fuel getting to the filter on top of the engine. FICM has 48.5 volts and drops to 20 when fuel pump kicks on, then back to 48.5 and drops to 20 while engine is turning over. Did an EGR delete about a year ago which explains a couple of the codes. Tried to clear codes and re-read. It still has 403 & 405 (EGR), 611, 671, 672, 673, 674, 675, 676, 677, 678. Checked fuses and tried click test-not a single click. Any ideas? Thanks!
mdegraw7@gmail.com is offline
Tags
ficm dtc 0611 code
