6.4L Powerstroke Engine Oil Leaking...
Hey guys / gals, new to this site had a question and would appreciated anyones input. Have a 2008 6.4L f350, new short block and cylinders. top end is the old one. Have put on 6000kms on new engine noticed engine oil dripping from both side rear corners of heads so around head gasket. No antifreeze in oil or vice versa, no white smoke, no loss of power and runs smooth. looks like from half way down the side of head gasket to the rear its sweating but the dripping is accumulating where i said prior?? I do have it programmed but have been babying it except once stepped on it fairly good to pass a semi. Possible head bolts stretched?? or??
