Engine will not run after changing oilhousing
Hello
i have a problem with a 2004 F250 6.0L after changing the oil filter housing seals( because they are leaking oil) i want to start the engine, the car starts but won't run I check the oil pressure lop was 70 psi and the hop was 110 psi i think that that's the problem but how now does any one has a idea? greetings from the netherlands |
High pressure oil leak somewhere. Are you building more pressure the longer you crank. Like try starting, do 15 sec and see if you can build more pressure. Did you use Oem oil filter and cap? If not that could be your problem.
Sent from my PG06100 using AutoGuide.Com Free App |
Yes the pressure runs up and yes i replaced the parts for motorcraft oem
because we are in the netherlands an there are not a lot of pick-ups around here we mis the tech info, but the parts are coming from the usa once a week thanks |
No problem did you get the problem worked out?
We put 8 new oem injectors in the car and it runs super. so it like nothing to do with the oilfilterhousing
Re: Engine will not run after changing oilhousing
Nice :thumbup:
