Life after EGR Delete/Bypass p2290 - Ford Powerstroke Diesel Forum
Old 07-06-2012, 03:20 AM
After I did bypass surgery on my 05 6.0 Excursion i am dealing with a new problem that was not there before. I am getting a p2290 code pop up when i hit higher speeds while passing tourists here in Montana. Any help on this issue would be much appreciated.
Old 07-19-2012, 11:06 PM
Your obd2 code reader display the code P2290 that means "Injector Control Pressure Too Low", for this, you will know where is the problem and fix it. luck for you!
