egr valve or egr cooler.oilcooler...f350/6.0L - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-04-2012, 09:06 AM Thread Starter
Cool egr valve or egr cooler.oilcooler...f350/6.0L
i have f350 6.0 L 2005 diesel that has always ran with temp @halfway mark. recently started smoking(white) at 1/4 temp mark and stopped at halfway temp mark. losing water in coolant system slowly(20 miles a day, fill once a week maybe). got hot, gauge climbed almost to red once, but stopped to let cool right then and the gauge would drop if rolling fast with engine idling. hard to start one time and black liquid(soot/water) out muffler a few times. could this be the egr valve or egrcooler,oilcooler,etc......
thanks for any help....
johnny
johnnybeck is offline
post #2 of 5 Old 06-04-2012, 09:37 AM
turbotibbo's Avatar
sounds like an egr cooler has **** the bed . i would not be driving it or you may hydrolock the mortor and also may blow the hesdgaskets . also if you do find out its the egr cooler u better replace the oil cooler cause thats what killed the egr cooler . it gort pluged with sand or silacates
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 5 Old 06-04-2012, 12:38 PM
The Silent Service
colo_dually's Avatar
Quoted: 15 Post(s)
You have a bad oil cooler, which has lead to a bad EGR cooler. Time to stop driving the truck until you can get everything organized for a repair, and that includes the time to learn everything you can about what happened here and ways to prevent it.
I had the same thing, looks like its time to start reading up on the 6.0L and getting it figured out. Here's my write up:
Write Up: Bullet-Proofing the 6.0L PSD.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #4 of 5 Old 06-09-2012, 10:11 AM Thread Starter
great. thanks for ya'lls help, i am most greatful. thinking about replacing with an upgraded egr cooler and oil cooler as well. is the upgraded egr cooler easier to install than a delete kit? also, should i flush the whole coolant system as well in the mist of all this. once again thanks very much for ya'lls help. johnny
other thans this, knock on wood, my truck has been superduty......
post #5 of 5 Old 06-09-2012, 10:32 AM
I'm agreeing with colo-dually on this one. I haven't been through it myself, but I bet the oil cooler caused the xcessive temps in the EGR cooler which resulted in the failure. Do not simply change the EGR and continue to drive it.
It sounds like you're one of the lucky ones that caught it before the major damage occured. There are many threads on here about monitors; scangauge, insight, etc. That will allow you to monitor those temps and catch that before it ruptures. I haven't bought mine yet, but will be doing so very soon. There's some good people on here with great advice!
How many miles on the truck?
Oldtime Racer is offline
