ENG WIRING HARNESS
I thying to find out what this relay is
or does part # 1821712c1 IT ATTACHED TO HARNESS THAT GOES TO GLOW PLUGS CAN"T GET TRUCK TO RUN 1994 F350 7.3 TURBO F NEW FUEL PUMP ON I REMOVED REAR TANK TO INSTALL WHEEL LIFT TOW UNIT BLOCK OFF FUEL LINES,INSTALLED NEW FUEL PUMP,NEW FILTER,CHANGED OIL GOT IT TO START,FINALY AFTER TURNING OVER & OVER RAN IT FOR A FEW MIN;S SHUT OFF TO REINSTALL AIR FILTER ETC ETC AND NOW IT WON'T START ( GOT FUEL GOT POWER TO GLOW PLUGS) ??? HELP THANKS MIKEETT |
what is this?
That's what a quick search came up with. BTW.Well, when you turn the key on, does the WTS light come on? Have you tried a new CPS? Since you were messing around in the valley, I'd check the UVCHs and all their connections. Is it possible you just have air in the fuel rail since you changed out all that other stuff? |
| Tags |
| fuel issue |
