post injector help!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-03-2012, 09:06 AM Thread Starter
So i just finished an injector job and the truck started for a few seconds, then quit. Now it is throwing camshaft and crankshaft position sensor open codes. Is there something logical that I can check? water on a connector common problem spot on the harness??
Dplafle is offline
post #2 of 5 Old 03-03-2012, 09:43 AM
jesilvas's Avatar
Quoted: 3 Post(s)
What motor?
I BET, if it's a 7.3 or 6.0 with HEUI injectors, then you just need to purge the air out of the oil/fuel rails.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 5 Old 03-03-2012, 10:11 AM Thread Starter
Possibly cause i ran the batteries down starting it the first time?
Dplafle is offline
post #4 of 5 Old 03-03-2012, 10:15 AM Thread Starter
should have clarified.... She is an 04 excursion with the 6.0.... Could that be why she's throwing p2614 and p2617?
Dplafle is offline
post #5 of 5 Old 03-03-2012, 10:32 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Probably excessive cranking. I'm not positive, but maybe that's why they showed up.
4R100, 2wd
330,000 + miles
jesilvas is offline
