95 f250 7.3 injector might be bad - Ford Powerstroke Diesel Forum
Old 12-22-2011, 05:35 PM
i thing my injector might be bad when i start the truck up in the morning and take off when i hit 40mph the engine will start to shake and when you step on the gas it go away when the truck warm up it dors not do it but the rmp well move a little bit
Old 12-22-2011, 05:41 PM
That's a big thing to start at. Could be a loose UVCH making intermittent connection making it seem as though it's missing. U joint. Trans. Diff. Drive shaft. Could be the EBPV closing when cold like it should. You could unplug it from the base of the pedestal and see if it stops.
Old 12-22-2011, 05:49 PM
ok when it idle the rpm move and the steering wheel shake a little took it to ford and they said to replace the idm so i did and still the same took it back they still said i had all 8 injector were no good that hard to believe after one day they all go bad
Old 12-23-2011, 02:49 PM
It sounds like they have no idea what they're talking about.
The RPMs move and wheel shakes. Vague.
Does it have any codes? You said it's only when cold?
I'd check the UVCHs first.
