07 psd Intermittent whistle or "tea kettle" - Ford Powerstroke Diesel Forum
Old 12-07-2011, 11:06 PM
Im having trouble with my new 07 6.0 psd bought used 115k. Im having an Intermittent whistle or "tea kettle" sound varied with RPM and bad mpg. can somebody please help
Old 12-08-2011, 06:03 AM
what are you getting for mpg. and are you talking about the turbo whistle?
Old 12-08-2011, 06:05 AM
Tea kettle noise will most likely bo over-pressurizing of the cooling system and the degas bottle cap venting the pressure. What kind of shape is the oil cooler and egr cooler in?
Old 12-08-2011, 08:53 AM
no its a beaping sound that i will get when increasing rpm or going up hill and im getting no better than 9-13 mpg
Old 12-08-2011, 08:56 AM
could it be a popped IC boot?
Old 12-08-2011, 09:08 AM
i was loosing some coolant and my heat sometimes doesnt work if im stoped
but i replaced some bad intercooler boots on the passenger side and the beaping hasnt been as loud or as frequent.im not sure on oil cooler or the egr? i will check the egr cooler but idk about the oil cooler. i know where its at but dont know what to look for. im new to diesels and onlly know so much.
Old 12-08-2011, 09:14 AM
i replaced the two riped and torn passenger side intercooler boots the other ones looked fine no oil seepage. like the rig by the way
Old 12-08-2011, 10:10 AM
To check the oil cooler you need to get a data monitor of some sort. I personally like the Edge Insight CTS, but the ScangaugeII is a great option as well. You need to monitor the difference between oil temp and coolant temp. If the oil is hotter by more than 15* then you need a new oil cooler. The coolant loss could be a bad egr cooler or again bad heads or cracked heads.
Old 12-08-2011, 10:28 AM
would a diagnostic computer get me the this info? i added some coolant because my heat wasnt working and was loosing coolant from the degas bottle cap but have not seen any loss in coolant since the past week.
Old 12-08-2011, 10:48 AM
Yep diag tools(scan tools) will give you the necessary readings, but in my opinion you need to have a good data monitor on the truck all the time. Invest in a data monitor
