2006 6 liter water in fuel light
My water in fuel light is on. Is there a drain on the bottom of the filter or somewhere else? My turbo also goes to about 30 lbs. boost. is this normal ??????
Yes, there is a drain on the HFCM located under the drivers side of the cab, mounted to the inside of the frame rail. 30 PSI seems a little high, are you tuned?
TUNED ???? just came out of the shop.. I think it should be .. don't know though .. help
Tuned... as in running a programmer? a chip?
Yes a chip Edge
Boost looks to be normal with it being chipped.
how does a person CHAT on here?
so that is a pic of the Valve assembly on the drivers side , in the frame
