Help! Everything I do makes it worse. - Ford Powerstroke Diesel Forum
Old 11-06-2011, 05:22 AM
I have a 99 F350 with 130k. It does not get used much. It is serviced reguraly.
After driving about 5 miles it started running rough. I accelerated and the service engine soon light came on briefly. I limped home. Upon removing the air filter I found it extremely dirty. I cleaned and reoiled it (K&N) and reinstalled it. No real difference, still running rough. I disconneted both batteries and changed the fuel filter. Reconnected batteries, started truck. It idled fine, very smooth. As I started to test drive it, it began running rough. When turning around to return (about 1/4 mile) it died and will not restart. I checked the fuel filter installation and found nothing wrong.
Any advise, other than to let someone that knows what they are doing work on it?
Also, I do not have access to a scanner.
All help and advice appreciated.
Old 11-06-2011, 06:31 AM
Feedback Score: 5 reviews
Does the Tach move when cranking?
Is the WTS (Wait to Start) light coming on/off like normal?
All fuses checked/good?
Old 11-06-2011, 06:32 AM
Also, where you located? Might be someone local who can scan it for you! Good luck!
Old 11-06-2011, 08:16 AM
ToMang07
Thank you for your response. Yes, the tach moves when cranking, the WTS light comes on and goes off properly, and all fuses have check out ok. The engine will "almost start", knocking badly when it does and runs for a couple of seconds.
All help appreciated.
Old 11-06-2011, 08:18 AM
ToMang07
Sir, I am located in Boerne, Tx 78006, about 20 miles north of northwest San Antonio, Tx.
Old 11-06-2011, 08:24 AM
ToMang07
Also, sir, I am not familiar with this site and have had gread difficulty finding my post as well as other searches. You are welcome to email me at: bubbaslater@aol.com
Thank you
Old 11-07-2011, 02:23 PM
Guess I said or did something wrong. No response for anyone.
Old 11-13-2011, 11:41 AM
it could be the IDM module injector-control-module
