egr codes no turbo on take off
just wanted to post a quick note. I have a 08 f250 6.4 i was throwing a egr dtc and was in limp mode. i took off the plastic sensor cover on the egr valve and found that the pins that connect the sensor to the electric motor that activates the egr valve had corrosion like a battery terminal in one of the holes in the housing....with this said i was not getting the voltage to let the valve operate when the computer wanted it to...running strong after a 5 min cleaning
