My truck took a little more time to start than it normally did. As soon as I pulled out my check engine light came on. It didn't make any noise just loss of power. When I went to start it the next day the truck turned over and tried to start but nothing else. I could here the clicking under the hood getting weaker. I have already replaced an Injector in this truck. I think it is my Fuel Injector Pump? What do you think?
I bought this truck only a few months ago at 117,900 miles on it. Shortly after I had to get an injector fixed.Within a few weeks the check engine light came back on and then turned itself off within a few weeks for no reason. Now this. . . . Should I just get rid of it? Last edited by amasters0711; 09-01-2011 at 11:30 AM. |
Not the pump.
Pull the codes since your SES is on. most likely the FICM. |
How do you figure? My neighbor is a mechanic and said he thought it was the Pump because you could here what I assume the pump getting weak every time we just turned the key to on. It sounds like the what you said would be a cheaper fix. I can let you know what the codes are tomorrow.
Thank you! |
Does your neighbor work on PSD's?
We dont have injection pumps. |
Forgive me not knowing much. So if I understand correctly there is no Injector pump on the 06 F250 6.0L?
There is a detailed FICM repair procedure at
FICM pictures by DrQuad - Photobucket |
FICM or High pressure oil system leak
check your batteries! Anytime I see an injector go bad, I recommend updating the fuel pressure spring if not already done. |
