Things to look for when buying - Ford Powerstroke Diesel Forum
Old 08-28-2011, 05:02 PM
Hi guys, I'm new to this forum. I'm currently looking at this white 2005 Ford F-350 diesel. It's got 294,850 kilometers (183,211miles) on the clock. I would like to know what to look for problems? What exactly should I test at the dealer? What are the key things?
Thanks guys!
Old 08-28-2011, 05:08 PM
This has been discussed so many times... I can't believe I'm responding. I see this is your first post. If you scroll to the top of your screen you'll the the 'Google Custom Search' box. The search button on the actual menu bar doesn't work too well. Trust me when I say that the google one works very well. I did a search for you and this is the best thead I found brother... welcome to the forum.
What to look for when buying a 6.0???
Old 08-28-2011, 05:11 PM
And here's Mitch's write up. He discusses coolant issues and how it relates to head gasket failures among other things. Good read.
Things to consider about owning a 6.0L
Old 08-28-2011, 07:16 PM
Thanks alot! I'll read them both. I'll use the search next time!
Old 08-29-2011, 08:24 PM
The fix for a 6.0 is a 7.3 -- or better yet is a duramax I have a 95 f250 with a 7.3 --- and a 05 silverado 2500 with a duramax LBZ
