Checking HPOP, graph look ok? 7.3 using AE - Ford Powerstroke Diesel Forum
Old 08-08-2011, 06:00 AM
This is a graph of two WOT runs. The 4 sensors are ICP, ICP DC, Engine rpm and MAP. You'll see the first downshifts. The 2nd was a longer run. I'm having an issue where it feels like i'm towing a 10k# load while driving normally. Engine sounds fine, but seems like its working harder to make the same power. Does the HPOP look as if its up to snuff?
