06 6.0 problems - Ford Powerstroke Diesel Forum
Old 07-25-2011, 12:40 PM
06 6.0 problems
I have a 06 F250 6.0 that started running rough, then hard or no start when warm, usually cold, a host of codes: P0113,0269,0284,0299,0403,0404,0405,0478,2290,2464 , no smoke or steam issues, is this an electrical issue causing all this?
Old 07-25-2011, 01:24 PM
information regurgitator
For informational purposes:
P0113: Intake air temp sensor 1 circuit high
P0269: cylinder #3 contribution/balance
P0284: cylinder#8 contribution/balance
P0299: Turbo underboost
P0403: EGR valve control circuit
P0404: EGR control circuit range/performance
P0405: EGR Sensor "A" circuit low
P0478: Exhaust pressure control valve high input
P2290: ICP too low
P2464: I can't find a listing for this code.
Sounds like an electrical gremlin has attacked your truck!
Old 07-25-2011, 06:34 PM
Powerstroke Techie
Feedback Score: 3 reviews
time to go to the shop. while you have a lot of codes they're likely not related to an electrical problem. every one of those dtcs seems to point to a pretty common issue
EGR valve, clean the turbo, STC, dummy plugs and a few injectors.
Old 07-29-2011, 06:19 PM
engine light came on, O'reilys computer says exaust gas problem detected, just purchased 6.0, 06 ford f250, spuper duty, 6 speed man tran, any idea what's wrong
Old 07-30-2011, 08:31 AM
When getting your truck scanned for codes, it is MUCH more helpful to get the code number than what they tell you the code means. Their description means little, if anything. Get the code number.
Old 08-15-2011, 10:07 AM
05 f250 6.0
followup on my recent post and still have issues, replaced 4 injectors, hpop, dummy plugs, did EGR delete, runs great down the road now, NO DTC's at all however still WILL NOT hot start, cold is fine, wth is with this?
Old 08-16-2011, 05:48 AM
Since when oil gets hotter, it flows more freely, hard starting hot points to a high pressure oil leak.
Since you just did injectors, HPOP, dummy plugs and standpipes (I assume standpipes and STC fitting were addressed), take the valve covers off and watch for it. Might be the o-rings on top of some of the injectors.
Old 02-25-2012, 03:46 PM
Oh ok sounds good..
