05 PSD wont start
Hey guys,
2005 f350 psd,, it wont start. It will almost start, and sometimes does, it will lope 2 or 3 times then die. Either started to get it running, but that even took a while. But after it started and warmed up, ran good for the day and never had a problem starting it that day but the next morning same thing. its warm 65 degrees,????? any ideas, Fuel fiters just changed a month or so ago, all fuses seem to be fine havent changed the CPS,EGR yet, not thinking it is the problem |
You need to have codes pulled. Then track it down from there. Try and test your FICM, it may be bad (symptoms are the same)
I SOOOO beat you to it!
Yeah, but at least he can open my link without having to join another forum
bahh-I'm not a member and I can view it!
I can't
![]() I guess I wasn't giving it enough time to load . Yeah, well, at least mine came from the ORG ![]() ![]() ![]()
