GDS Fuel Spring Problem! PLEASE HELP!
I just installed a GDS FPR spring. It's suppose to be like the shim or bb mods. I put it in perfectly fired the truck up it seemed to run fine. I took off down my road then my truck acted like it ran out of fuel (it has 1/2 tank). Now it won't crank or run at all. I've tried taking it out and putting the stock spring in several times and nothing it won't hit a lick. Please help! Thanks in advance!
check your fuel pressure, is the pump still pumping koeo?
I'm not sure. I don't think so. I took the filter cap off and cycled the key and turned it over but no fuel in the bowl.
Well actually there was about a quarter of an inch but it wasn't full...
And when I cycle the key no more pumps in.
I would make sure you still have power to your fuel pump, and if so then replace the pump. You could have had a weak pump and the added pressure of the new spring caused it to fail.
