im new on here, any help would be grate, i got a 2006 f350, 6.0 with juice and exhaust. i tow a 40 foot 5th wheel. have had lots of problems, 2 egr coolers, oil cooler, 2 turbos, and head gaskets and stud kit, i got 90 k on it and now i was driving to a motocross race and my milage was droping, it started to drop speed and run rough, it slowed to about 20mph. so i stoped and got fuel filters, it ran better i could go 65 but souded like it was dropping a couple cylinders, i got to where i was going and let it sit for the weekend. drove it home and my juice codes were low injecter cirquit on 1 and 5 injecters. i checked the ficm box and it was good. the local ford shop said it was about 5 lbs low on fuel pressure and two bad injecters. what do you guys think. thanx
could
you tell us what has happened so far facing my own probs with my 04 very similar to yours, trying to pick up tips thanks |
I'd say by what you said the pump is bad... Not totally shot, just malfunctioning... Pulled over replacing filters cleared a fresher path but did you see any shards when pulling the fuel filter(s) ? I think you need to replace that Pump before it rips apart more of your injectors... When you said you were suddenly loosing mileage I would put money on it that 1 and 5 had caught a fragment and were stuck open... I mainly see it in the older years such as 03 - 04... Just a thought man
