2000 superduty wont start - Ford Powerstroke Diesel Forum
Old 04-21-2011, 08:47 AM
Engine was running real rough and no power to speak of found bad clips on valve cover gasket replaced gasket and harness, engine started right up ran fine let it idle for awile then shut it off replaced fuel filter and gpr, needed done anyway. started truck no problems shut it off and thought it was fixed. Went to use truck the next day started fine ran for 2 min shut down, restarted shut down, wont start at all now. Checked fuel bowl it is getting fuel batteries good cps good tach moves when cranking, no smoke or otherwise when cranking no codes help!!!
Old 04-21-2011, 11:26 AM
Illiana Chapter Director
"Wait to start" light coming on when key is turned on?
Old 04-21-2011, 06:09 PM
have you done the cam sensor recall within the last 50,000 miles?
Old 04-21-2011, 06:36 PM
Check your oil level. If oil level is to low the High Pressure Oil Pump will not pressurize the injector for the fuel. This will cause rough running and even to not run at all. Could be a bad HPOP.
Old 04-22-2011, 03:53 AM
never taken truck in for recall but i have put at least 3 cps sensors in it I keep a spare. when cranking the oil pressure comes up good in the gage, i checked the injector solenoid and its not making contact when cranking. I cant find the port to check fuel pressure and how would i diagnose the HPOP
Old 04-22-2011, 04:24 AM
there isnt a port to test fuel pressure, i usually connect atfter the pump on the quick disconnect, its a 3/8 line i think. where r u located.
Old 04-22-2011, 04:28 AM
The wts light does come on I am in WV
Old 04-22-2011, 04:31 AM
fresh oil change level good
Old 05-20-2011, 09:18 AM
how do i ask a question on this forum??? it seems i can reply to msgs but cannot find any way to ask a question. pls help,,,could be headspace
