Coolant flush - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-26-2013, 02:56 PM Thread Starter
nuttz565's Avatar
Quoted: 5 Post(s)
Coolant flush
So this Thursday I'm going to be changing the coolant out on the 6.0. This is my first coolant flush on my truck so I'm hoping some of you can chime in
1. What kind of coolant are you running? I'm thinking about switching over to a ELC but then again I have two unopened gallons of the Ford stuff in the garage
2. I know there are two plugs on the engine block one of which requires removing the starter to get to. Do you bother with the drivers side or is it okay to just remove the one?
So I'm off to get some distilled water and a new thermostat since my ect never gets above 184.
Thanks guys.
2006 F-350 SC LB
4"Straight Pipe
XDP Coolant filter
Blue spring
Visteon air cleaner
Rudys CAC pipes,boots&elbow
Viper remote start
nuttz565 is offline
post #2 of 12 Old 03-27-2013, 05:27 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1133 Post(s)
Feedback Score: 6 reviews
I haven't done mine yet, but have tossed the idea around in my head about switching to ELC, still not sure yet. I've been thinking about replacing my T-stat as well, I get up a little over 190, but not much. Keep me posted on what you end up doing and how you went about it.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 12 Old 04-03-2013, 08:19 PM Thread Starter
nuttz565's Avatar
Quoted: 5 Post(s)
Ended up running about 40 gallons of distilled water through it. Did this until it was coming out clear from the radiator and engine block I went ahead and put back in the ford Gold for now. Took me about a day and a half to do this( every time I drained it and refilled with distilled water I let it high idle for about 60 min or so) It was kind of a pain in the a$$, I was probably under my truck at least a dozen times or so draining and re-draining the block.I figure as long as I do this every 30k or so miles the Ford Gold should be fine. Now on to see if I can figure out the "clunking' noise that happens under the driver side every time I turn.
2006 F-350 SC LB
4"Straight Pipe
XDP Coolant filter
Blue spring
Visteon air cleaner
Viper remote start
nuttz565 is offline
post #4 of 12 Old 04-03-2013, 08:30 PM
2500TD's Avatar
Did you buy the distilled water per gallon at the store, if so that must have been pricey? Ive always used hose water
1996 F250 CCSB 2wd, 5 Inch exhaust, project underway
See my Build Here
2500TD is offline
post #5 of 12 Old 04-03-2013, 08:41 PM Thread Starter
nuttz565's Avatar
Quoted: 5 Post(s)
I did buy it, I got a good deal for it at .50 a gallon. I could have used my hose for the first few flushes but I figured why not because of the price. I'm not sure if it makes a difference or not, heck I know the dealership sure the he!! don't use distilled water but I read a TON of posts suggesting it. After the last flush I put in 3.5 gallons of concentrated Gold and then topped off with the water. I just did a test on it today and I'm spot on.
2006 F-350 SC LB
4"Straight Pipe
XDP Coolant filter
Blue spring
Visteon air cleaner
Viper remote start
nuttz565 is offline
post #6 of 12 Old 04-03-2013, 09:27 PM
2500TD's Avatar
It makes sense, never really thought much of it. However I have always done flushes in regular everyday cars with a garden hose, premixed in any performance application. You bet ill be using distilled when it comes time to fill my coolant.
See my Build Here
2500TD is offline
post #7 of 12 Old 04-04-2013, 06:19 AM
RIP Cam!
What made you go back to the Ford gold instead of putting in ELC, Casey?
post #8 of 12 Old 04-04-2013, 06:42 AM Thread Starter
nuttz565's Avatar
Quoted: 5 Post(s)
Honestly I probably would have went with a ELC but I already had 2 gallons of the gold sitting in my garage(couldnt justify letting $40 worth of coolant go to waste). The debate about the Ford Gold and whether or not it does more harm than good to the motor I believe depends on the frequency of how often you change it. Ford at one point said it was good for 7 years or a 100k miles. I think if you stick to the 25-50k mileage range it will be fine. I'm planning on changing mine out in the 30k range at which then I will probably go with a ELC
2006 F-350 SC LB
4"Straight Pipe
XDP Coolant filter
Blue spring
Visteon air cleaner
Viper remote start
nuttz565 is offline
post #9 of 12 Old 04-05-2013, 05:47 AM
RIP Cam!
I see. Nick and I have discussed the whole coolant thing many times and both are still running the gold. I need to flush my system soon and need to figure out which way to go. My concern is that if I flush the gold out and then go with ELC I will end up with a clogged up oil cooler.
post #10 of 12 Old 04-05-2013, 05:25 PM
Bderick67's Avatar
Did you flush with any of the chemicals or just the dist water? Been thinking of doing the reverse flush on my oil cooler.
Brian
early 2004 F250 CC SB Lariat FX4
* with BPD Oil Cooler/cold weather pack * BPD EGR Cooler * Scangauge II * Blue spring update * Blue wire fan mod *
* Rotella T6 w/ Archoil 9100 * 4" catback exhaust w/5" tip
* 63,5xx miles *
Bderick67 is offline
