Ball joint info - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-24-2013, 08:38 AM Thread Starter
nuttz565's Avatar
Ball joint info
Hey guys, so my ball joints are on there way out. I'm debating if this is something I want to tackle or not on my own. I try to do as much work as possible on my own truck. I've watched a couple videos on how to's and think I'm going to go for it. I was just curious if anyone on here has done them and have any advice. I'm going to go rent a press from Oreilly's as getting them out seems to be the biggest issue. Thanks
Also if you have done them or had someone do them what brand did you go with-Moog,Oem??
nuttz565 is offline
post #2 of 5 Old 02-24-2013, 09:30 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
I've done a set (on a obs and a powerstroke van) moog, air hammer, heat, and/or "press"... Not to hard just takes a while.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 5 Old 02-24-2013, 10:04 AM Thread Starter
nuttz565's Avatar
Thanks. Looks like it's mainly just time consuming. I can get 4 Moog ball joints for 160$, most places want to charge between 800-1000$ to do this. Do you remeber what else you needed besides the ball joints?, seals, rings etc?
nuttz565 is offline
post #4 of 5 Old 02-24-2013, 10:45 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
Can't compare, van was 2wd, and obs are ttb front end. But I didn't need to do anything else on the obs, on the van did a new hub/bearing...
dannanw is offline
post #5 of 5 Old 02-24-2013, 10:53 AM
ZMANN's Avatar
Quoted: 1344 Post(s)
a seal installer or DIY tool
search Guzzles
We Miss you Ronnie
ZMANN is offline
