Truck is having issues - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-26-2011, 10:14 AM Thread Starter
DutchVDub's Avatar
I towed the Jeep up past Idaho Springs yesterday and right before I got there the truck started running rough, seemed to me it lost an injector or two. The boost gauage would get erratic under load and it was letting out grey smoke. As I was pretty much there I just pulled into the fuel station where I normally stop to meet with people before heading to the trailhead and unloaded the Jeep.
I got done with wheeling and loaded back home. I started the truck and it was still missing. I pulled out of the fuel station and started heading back home, figured I had no other choice as I couldn't afford a tow from there plus I had the Jeep and trailer.
Started heading back down the pass, the truck was definitely down on power and continually blowing grey smoke when I would give it throttle. Shortly afterwards it started making a really loud tapping/knocking noise that was RPM related. I got all the way back to my exit but when I stopped at a the traffic light just past the exit ramp the truck died and wouldn't start. I managed to get a couple guys in an F-150 to strap me the 3 miles to my house, trailer and all.
This morning I made sure the HPOP resevoir had oil in it (it did) and tried starting it again, no dice. Just for ****s I sprayed a bit of ether at the airfilter and tried again. It started up and continued to run, grey smoke coming out of the exhaust the entire time. I unloaded the Jeep and unhooked the trailer, truck kept running the entire time. I then drove it up my driveway and parked it. After I shut it off I waited almost a minute and then tried to start it up again. It fired up, although a bit hesitantly.
So thats where I'm at now. I'm glad I can get it to start, that makes it easier to test. I've got a guy thats going to bring a scanner over tomorrow to see if there are any codes and to perform some tests. I'm also going to pull the valve covers off and check the wiring there. Any other hints?
2001 F250 CCSB 4X4 Lariat: TS Chip, Mag-Hytech diff cover, Hughes Alum trans pan, A-Pillar gauges (boost, trans, EGT), MBRP exhaust, 6.0L trans cooler
2008 Jeep Wrangler Unlimited Rubicon: 3" lift, 37's, trussed axles, full aluminum skids, cage, and more all powered by a minivan motor
2013 Kawasaki 1400GTR : Muzzy's exhaust, Muzzy's lowering links, Throttlemeister
DutchVDub is offline
post #2 of 11 Old 06-29-2011, 09:31 AM
99liftedstroker's Avatar
do you have a video of it running? it could be the injector cups went bad. is there oil in the coolent or coolent in the oil
michael
e99 f250
h2e turbo
4in exaust in to 5in stacks(home made)
suncost trans
160cc ddp stage 2 sticks coming soon
custom tunes and 6pos chip soon
17* hpop..
im on a roll anyone wanna sell a regulated return?
99liftedstroker is offline
post #3 of 11 Old 06-29-2011, 05:51 PM Thread Starter
DutchVDub's Avatar
I'm prerry sure I've got it nailed down to a failed injector. Cylinder 5 failed the cylinder contribution test but passed the buzz test. I'm going to replace both UVCH's and swap a different injectors into cylinder 5. While I've got the cylinder out I'm also going to do a compression test on it to make sure nothing else is going on.
No coolant in the oil or vice versa, no bubbles in the coolant while its running, no smell of burning coolant while it was driving, and no white smoke while it was driving either. I'm pretty sure the headgasket and cups are good, but again I'll run a compression test on my failed cylinder just to be sure.
post #4 of 11 Old 07-18-2011, 08:51 AM
OverkillMotorsports's Avatar
Is this thing fixed yet?
1995 Ford Powerstroke F-250 4x4
Regular Cab Dually
Mods:
44" TSL super swampers
F150 Lariat seats
AFE Stainless exhaust
Hydroboost
Hi-Steer arm with drag link
Gauge faces all switched to white
3 POD pillar with Boost, EGT, Fuel Pressure
5.5" Shackle Reversal Kit
Southbend Single mass flywheel conversion
Southbend CON-OFE clutch kit
Tony Wildman 6 position chip
OverkillMotorsports is offline
post #5 of 11 Old 07-22-2011, 05:08 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 903 Post(s)
Feedback Score: 6 reviews
Yeah, what the hell? Is it fixed yet?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 11 Old 07-23-2011, 09:12 AM Thread Starter
DutchVDub's Avatar
Getting ready to strap it to Jared's "shop" now. Then it will be taken apart and fixed in the only way I know how to fix a Ford, by taking it to the scrapper.
I will say this is my first Ford I've ever owned out of nearly 30 cars. Its also the first vehicle I ever blew the engine up on. I'm just saying.
I'm getting me a fuel sipper first and then I'll be saving up for another 7.3L, most likely a Superduty this time. I figure they already have a 17deg pump, intercooler, and 6spd transmission so I'll probably go that route.
post #7 of 11 Old 07-25-2011, 08:17 AM
Your first mod should be an EGT gauge when you get another truck whether its a Chevy , Dodge or FORD as diesels are different then gassers.
DutchVDub's
I just towed the Jeep up HWY-7 from Lyons towards Estes Park and man am I glad I don't have an EGT gauge to look at. 3000rpm at 40mph in 3rd and spiking upwards of 17psi for a very long time up that hill. I bet I fried my pistons on that one.
Regular Cab Dually
Mods:
F150 Lariat seats
Hydroboost
post #8 of 11 Old 07-25-2011, 04:07 PM Thread Starter
DutchVDub's Avatar
They are? Really? I had no idea.
Tow 65,000lbs up a steep hill in a real truck and tell me how to tow with a diesel.
When you hold a higher rpm in a lower gear you use less throttle and therefore less fuel to make power, so even with the boost levels being the same your egt's stay down compared to full throttle in a higher gear and lower rpm. This might have been my first diesel that I personally owned but its not the first diesel I've been around. I've been maintaining and operating diesels for over a decade now, and I've hauled with them a lot.
post #9 of 11 Old 12-01-2011, 04:38 PM Thread Starter
DutchVDub's Avatar
Problem resolved
post #10 of 11 Old 12-02-2011, 12:30 PM
RIP Cam!
Quoted: 903 Post(s)
That's one way to fix it.
