squeaking under the hood. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-29-2010, 04:00 PM Thread Starter
MeltonUnlimited's Avatar
I have just started to notice some squeaking under the hood. Not belt squeal, but actual squeaking while the truck is running. Bearing maybe?
Joe
2006 F250 Lariat FX4
4" Turbo back straight piped exhaust
MeltonUnlimited is offline
post #2 of 7 Old 11-29-2010, 05:43 PM
Gene's Avatar
Quoted: 3 Post(s)
Does the noise go away when you take the serpentine belt off? If so, try turning all of the pulleys by hand to see if one is sticking or loose.
Belt tensioner pulley or idler pulley would be my first suspects.
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #3 of 7 Old 11-29-2010, 05:50 PM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
yea beat me to it, the 6.o belt tensioner likes to have a bearing go out, at least my work truck did, I think jeff said somethin bout his too just dont rember
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 7 Old 11-29-2010, 07:13 PM Thread Starter
hm.... okay. I will check it out as soon as I can and let ya know whats up.
Joe
post #5 of 7 Old 11-30-2010, 08:37 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 822 Post(s)
Feedback Score: 6 reviews
Yeah, I have a squeak as well. It is not that bad and goes away pretty quickly. I know it is one of my pulleys, just gotta get in there and fix it soon.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 7 Old 12-29-2010, 02:52 PM
7.3Lariat's Avatar
Probably the 6.0. Maybe try putting in a 7.3. Should fix it right up.
______________________________________________
Mike
SOLD
Mods: BD-X monitor, 6637, BTS, GT38R, Snow MPGMax, International up-pipes, Hi-Flow Outlet, 5" Diamondeye, HPx, FRx, Gearhead tunes, Tru-Cool tranny cooler, Remote Start
376HP 791ft-lbs on 10.15.11
7.3Lariat is offline
post #7 of 7 Old 12-29-2010, 05:07 PM
RIP Cam!
Quoted: 822 Post(s)
... LAME!!!!
