Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > Cookin it Up!
Cookin it Up! Chili, steak marinades, desserts, cookout favorites, etc....FOOD!!!
Old 06-18-2008, 08:42 PM
bdpprocessors bdpprocessors is offline
Send a message via AIM to bdpprocessors
who else brews their own biodiesel here?
ive been brewing my own biodiesel for a while now i'm 16 and live in dfw tx. i was wondering who else does the same? i'm wondering what your results are? like mpg and power and preformance? note i'm not water washing my fuel i'm dry filtering instead!
Old 06-18-2008, 08:49 PM
binder man binder man is offline
I'm also 16 and about to start. I think I found one place with oil but its getting to be hard to find. What is your column for dry filtering like?
Old 06-19-2008, 08:27 AM
55 gallon barrel with a series of filters down to 5 microns and a settler i also have a water block filter at the end but all the water should have been out before the process.
Old 06-19-2008, 02:18 PM
O so you don't use resin then? you just filter and settle?
Old 06-19-2008, 02:38 PM
correct you can do this without having any problems at all in a truck older than 03
Old 06-20-2008, 06:24 PM
I'm set up for water washing. So it won't be that bad. as long as it passes the 27/3 test I don't care what method it is.
Old 06-20-2008, 08:30 PM
h2odrx h2odrx is offline
I'm with ya on that! to wash or not to wash? I've been working with this stuff fro about 3 years now!
Old 06-21-2008, 01:13 PM
ya mine passes the 3/27 every time no problem ive been on it for a few thousand miles and i'm loving it . do yall get the same mileage on bio as regular diesel?
Old 06-22-2008, 03:52 PM
well once I actually start getting some oil I'll tell you. I might not have enough to go full BIO but you can bet I'll at least be running a high %
