| Cookin it Up! Chili, steak marinades, desserts, cookout favorites, etc....FOOD!!! |
Ok guys I've got a friendly (or not) throw-down scheduled with a friend. While I love Beef ribs, the contest will use Spareribs.
I really need a tried and true rub and mop recipe please! I don't wanna lose! ![]() ![]() ![]() And yes I'll be smoking them, so if you use a certain type of wood, knowing that would really be helpful as well. ![]() |
I love smoking pork ribs. I've tried lots of rubs and sauces and these are probably my favorites.
First, you have to start with a good dry rub. Try this one: 3/4 cup paprika 1/4 cup fresh black pepper 1/4 cup course sea salt 1/4 cup turbinado sugar (turbinado sugar will not burn like regular cane sugar) 2 tablespoons garlic powder 2 tablespoons onion powder If you want a little extra heat add 1 tablespoon chili powder and 1 tablespoon cayenne Put 1/2 of this on the ribs the night before and put into a plastic bag in the fridge. Put the remaining rub on before you put them in the smoker. Let the ribs sit out for 1/2 an hour to an hour before smoking them. This is a basic southern mop sauce: 2 cups cider vinegar 3 tablespoons fresh black pepper 2 tablespoons salt 1 tablespoon worcestershire sauce 1 tablespoon paprika 1 tablespoon cayenne The best advice for a mop sauce is don't mop too often because every time you open the smoker to mop you lose heat. Try and do it every 2 hours or so or whenever you have to add wood. For the wood, hickory is by far the best thing to use and oak is a close second. I personally don't like mesquite for smoking cause it gets a bitter taste if you smoke for a few hours. Apple also works well and adds a kinda sweet taste to the ribs. Hope it goes well for you. Let me know. |
You rock Mike!
This recipe seems similar to one I found in my smoking bible, but do you mist the ribs at all?? |
What I've found that works better than misting is putting a container under the ribs with some kind of liquid in it. I've used Coke, apple juice, rum (always keep a shot or 2 out for the cook), anything to add moisture. This will keep the ribs moist during the whole cooking time.
smoke at 225 degrees for 2 hours, then wrap ribs in foil for one hour and continue to cook for 1 hour, unwrap the ribs and continue to cook for 1 more hour. I usually mop in the last 20-30 minutes of smoking.
Thanks Mike and RRSA!!!
My smoker actually has the water bowl above the flame and smoke. And R I will definitely try wrapping them as well!
Which cut of the ribs do you guys prefer?
I like top loin ribs. Lot more tender.
Just looked up my choices between stores that I could get to today, Meaty Back Ribs (?) or St louis.
Top loin ribs are from the back, so maybe that's what your meaty back ribs are. Not sure about St Louis ribs, but I think they're spare ribs, which won't be as tender or tasty.
