| Computer Geeks Gaming, Servers, Code, everything computer... |
BLUE SCREEN!!!
I am trying to install a revised tune on my SCT. I have triedto do it twice in the last 5 minutes and each time as soon as I plug in the tuner I get a blue screen on my computer and then it restarts itself. I'm worrried about doing it again. Has anybody heard of this problem or know what might cause it? How do I fix it?
I guess the third times a charm! I tried again and it worked fine. I would still like to know if anybody else has heard of this and how to fix it.
I hate Microsoft! Wish there was more mainstream support for Linux. |
try to update your firmware and tune revision on the tuner itself through sct website i had problems like that before i had to acctually send mine back because i wont read dtc
Blue screens are normally hardware/software incompatibilities. If the hardware has a problem with it then it will throw an exception causing a blue screen. If the software fails to use the hardware properly than it will do the same. The best thing to do is make sure that your computer/laptop is up to date and the hardware that you are using is also as well.
if you have a Serial to USB converter, make sure you have a good one. in other words, not cheap. the conversion isnt a simple process and those converters need proper drivers. if thats not it then it possibly a problem with your tuner/scanner device. |
There is no need for a Serial to USB converter here. All you need is an A-B USB cable, but good info anyways |
I don't know if I didn't see it in a previous post but did you recently add any new hardware to your computer?
