Any HAM radio guys out there!? - Ford Powerstroke Diesel Forum
Computer Geeks Gaming, Servers, Code, everything computer...
 10Likes
post #1 of 34 Old 12-11-2013, 04:40 PM Thread Starter
lookin4myPSD's Avatar
I'm curious about who all has a HAM license and is on the air a lot. I know a lot of guys are into CB here, but it really is a whole different world over on two meters.
I keep it simple, I have an old Alinco 2 meter, and a chinese HT that I use to talk on the local repeaters in Bradenton. Listen for KD8RCT!
Feel free to throw out your call sign, and just talk radios. I'm curious about who's into it here.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #2 of 34 Old 06-24-2014, 07:01 AM
shenanigans
junior125's Avatar
Quoted: 1575 Post(s)
Garage
I know this is an older thread and all but I'm somehow just coming on it
I've got my Amateur Extra just recently so if you happen to here KO0U that would be me.
I run a Yeasu FT857D which is a dual bander as well as HF and 6M rig that I use only as a mobile setup
Mike
2005 CCSB F250 4X4
junior125 is offline
post #3 of 34 Old 07-23-2015, 07:42 AM
neilster1's Avatar
Quoted: 8 Post(s)
WD4NET here.. QTH is Royal Palm Beach, FL. I haven't been active lately - just purchased my `11 F250 recently so the radio hasn't gone back in.
neilster1 is offline
post #4 of 34 Old 07-23-2015, 08:26 AM
Mr. Crossthread
waggonerj's Avatar
Quoted: 901 Post(s)
Garage
So the HAM radio is like a mini radio station? Like on Malcolm in the Middle?
Justin
2005 F250 FX4 Lariat 262k
ARP Studs - OEM Gaskets - Machined Heads
4" Straight Pipe - SCT X4 - SRL Extreme - 360 Turbo Rebuild at 262K
Riff Raff Boots and Clamps - Coolant Filter - Blue Spring
LED Headlights and Fogs - and bruised ribs from laying in the engine bay..
Slowly getting parts for the big 3 upgrade..
Check out MPA, those guys are pretty decent
TPB!
waggonerj is offline
post #5 of 34 Old 07-23-2015, 11:24 AM
shenanigans
junior125's Avatar
Garage
depends on how you set it up
Mike
2005 CCSB F250 4X4
post #6 of 34 Old 07-23-2015, 11:38 AM
Mr. Crossthread
waggonerj's Avatar
Quoted: 901 Post(s)
Garage
Oh. So a super CB then?
Justin
TPB!
post #7 of 34 Old 08-24-2015, 04:04 PM
FX4Josh's Avatar
CB and amateur radio are actually fairly similar in terms of operation and functionality. The METHODS of operation is completely different, and you'll find two totally different breeds of people on either. Well, unless you venture down to 40 meters, which could be comparable to CB at times. CB is still radio, and radio propagation characteristics still apply to it as it does amateur radio.
The primary difference as far as actual operation is concerned is that amateur operators have a larger span of bandwidth and frequency than CB'ers do, and amateur operators can at times (depending on frequency and license class) utilize more RF output than CB'ers are legally require to abide by. Amateur operators can legally transmit up to 1 kW (1,000 watts RF) depending on frequency. That's usually more than enough to get the job done. Some hams are quite the opposite and get a thrill from making a distant contact using as LITTLE power as possible (which is an FCC regulation anyway). It's not uncommon to talk to someone in another COUNTRY with only a few milliwatts (not even ONE watt).
I am both, actually. I'm an FCC licensed General operator, and I also fancy CB talking.
waggonerj likes this.
2007 F250 6.0 FX4
Eight cylinders of turbo-charged fury. Two are on vacation. One dosen't speak english.
Bulletproofed, ARP studs, Holders 175/75's, KC Stage 2, Tuning via SCT X4
FX4Josh is offline
post #8 of 34 Old 08-24-2015, 04:26 PM
Mr. Crossthread
waggonerj's Avatar
Quoted: 901 Post(s)
Garage
Ill just stick to my simple CB. Its mostly for fun now anyways since I moved into town. Thank you for explaining that though.
Justin
TPB!
post #9 of 34 Old 08-24-2015, 04:30 PM
FX4Josh's Avatar
That's one of the biggest things I enjoy about CB. It's simple. It's easy. It's fun.
There are dickheads anywhere you go. Even on ham radio. There are guys on some bands that make CB look like Sunday school.
2007 F250 6.0 FX4
FX4Josh is offline
post #10 of 34 Old 08-24-2015, 06:30 PM
shenanigans
junior125's Avatar
Garage
^^^ this, there was some bad people in Canada on 20m there for a bit, that finally got slightly cleared up
Mike
2005 CCSB F250 4X4
Tags
ham , radio
