Is this bad???? - Ford Powerstroke Diesel Forum
Computer Geeks Gaming, Servers, Code, everything computer...
post #1 of 19 Old 12-02-2013, 08:37 AM Thread Starter
HillbillyDeluxe39's Avatar
Is this bad????
Turned my computer on and this popped up. Should I be concerned?
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #2 of 19 Old 12-08-2013, 07:57 AM
No, it happens if the computer was turned off without shutting down.
Computer detected a potential hard drive issue and is resolving it.
GSchretter is offline
The Following User Says Thank You to GSchretter For This Useful Post:
HillbillyDeluxe39 (12-08-2013)
post #3 of 19 Old 12-08-2013, 07:22 PM Thread Starter
Thanks, something else must be wrong then. It's done this the last couple of days, usually over night.
2000 F250 CCSB 4x4
post #4 of 19 Old 12-08-2013, 07:50 PM
Yes, your hard drive is probably going bad. Time to back up files and budget a new hard drive.
post #5 of 19 Old 12-11-2013, 04:41 PM
lookin4myPSD's Avatar
Pick up an SSD, and use a new HDD as storage/backup. You will not be disappointed that you spent an extra $100-200.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #6 of 19 Old 12-11-2013, 04:42 PM
ZMANN's Avatar
Quoted: 1574 Post(s)
U can thank Porn for that
We Miss you Ronnie
ZMANN is online now
post #7 of 19 Old 12-11-2013, 04:47 PM
Misuse of software does not create fault in hardware.
Early 99 F250 ECLB,
post #8 of 19 Old 12-11-2013, 04:48 PM
ZMANN's Avatar
Who said it's misuse ?
We Miss you Ronnie
ZMANN is online now
post #9 of 19 Old 12-11-2013, 05:09 PM
hdodt's Avatar
ROTFLMGWMFAO!!!!!!
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #10 of 19 Old 12-11-2013, 05:46 PM
Yeah. I definitely said that wrong!...I meant "effective and fun use". haha, either way, you can get all sorts of viruses, but it won't actually hurt the hardware in any way.
Early 99 F250 ECLB,
