Anyone on here a mech. Engineer - Ford Powerstroke Diesel Forum
Computer Geeks Gaming, Servers, Code, everything computer...
post #1 of 6 Old 10-14-2013, 05:43 PM Thread Starter
matty21's Avatar
I've got a question about flow characteristics of an exhaust idea.
Some guys are hollowing out there DPF so it looks stock. What would it flow like with the downpipe being 4" then going to 8" for a few feet then to dual 4" exhaust with one 4"aero turbine muffler in each of the 4" duals. I've heard the aero turbine's aero foil design helps "pull" or scavenge the exhaust out but would the velocity crash once it hits the 8" section? I've also heard this will make the exhaust sound like stacks without having stacks. That sweet hollow grumble.
The more accurate and scientific the answer the better please.ill attach a crude drawing of what I mean.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #2 of 6 Old 10-18-2013, 11:38 PM
Quoted: 8 Post(s)
Yep, the velocity drops off as the gas expands into the chamber (which cools it as well) forming what amounts to a gentle 'plug'.
The idea is to keep velocity high without leaving laminar flow.
Doward is offline
post #3 of 6 Old 10-19-2013, 01:22 AM
srt6's Avatar
you are way over thinking this....
2012 F250
srt6 is offline
post #4 of 6 Old 10-19-2013, 01:31 AM
BIG Laing's Avatar
Matty, I find it funny that you are asking help from random engineers. I am working on a manufacturing engineering degree, and work with a lot of design and mechanical engineers, none of which could help you. You need a fluid dynamics engineer.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 6 Old 10-19-2013, 01:33 AM
BIG Laing's Avatar
Also, why 8"? Is that the I.D. of the DPF?
post #6 of 6 Old 10-19-2013, 01:54 AM
Quoted: 8 Post(s)
A single 4" exhaust pipe will be good up to ~550bhp. I hate to be the bearer of bad news, but everything from the point that your 4" downpipe connects to the 8" pipe is actually going to be restrictive vs a properly sized exhaust.
Now, if you are going for 'looks and sound' vs actual performance, then you're fine. If you're looking to draw every last bit of power, you're not quite on the right path
Doward is offline
