| Computer Geeks Gaming, Servers, Code, everything computer... |
To upgrade to ddr3 you will need a new motherboard.
8GB of ddr2, probably not cheaper than that. 8GB is alot of ddr2. If by donor, you mean build a new pc but use some of the parts from your current desktop, then yes. Most likely you can use everything except the motherboard. You may need a new CPU if its not recent enough, but if you are getting a new motherboard anyway, might as well get a faster cpu. Plus you can usually get a good deal on a motherboard/cpu combo. I guess before we get too far into this, what are you looking to accomplish with an upgrade? The reason I ask is that dram is not typically the bottleneck in a system. The hdd is the main bottleneck and an upgrade to an ssd would seem like getting a new pc. |
i kinda dropped the idea of updating this rig, i am still using it, but looking forward to buying a new one from a guy i know.
can hate the computer world, but would never live without them
Check out newegg.com You can get really good deals on motherboard/cpu/ram packages. Update for cheaper than replacing. If you could give a little info on what you have to work with I could help locate a suitable upgrade.
