wireless router help - Ford Powerstroke Diesel Forum
Computer Geeks Gaming, Servers, Code, everything computer...
Old 12-29-2010, 04:23 PM
Shaking the Bush Boss
I am computer ignorant, and need some help...
I need to install my Linksys WRT54GL router. I have internet service through Time Warner Cable...DSL... I have no CD or instructions for the wireless router. I dont know which order to connect the earthnet wires....into the cable modem, to the wireless router, to the computer....?????
Old 12-29-2010, 05:11 PM
To connect your cable Modem to your router, just use Cat 5 cable and plug it into the large port (RJ-45) on the back of your modem, most say (WAN) if not it looks like an oversized phone plug. Now connect the other end to the router; if you look on the back you will see a series of RJ-45 connections. The one you are looking for will be labled (WAN), plug it in there. Believe it or not, that's how you connect you router to your modem. Now for your computer to work, either your will need to physically connect it to the router by using Cat 5 cable or you can go wireless. If wireless the computer will have to have a wireless ethernet adapter card.
try this link, it will help, How to connect a cable modem to a wireless router | eHow.com
Old 12-29-2010, 05:39 PM
thanks. On the router, there are 4 hacks, and 1 off by itself that says internet... is this the WAN port?
Old 12-29-2010, 05:41 PM
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
Yes, the one all by it self is the one that goes to the Internet/ Time warner router. The other 4 go to any pcs you may have
Old 12-29-2010, 05:49 PM
on the back of the cable modem, I have only 1 port for the earthnet cable....
Old 12-29-2010, 05:56 PM
Ok, cable modem to the wireless router, router (1 of the 4 ports) to the pc..... bbl
Old 12-29-2010, 06:00 PM
On the cable modem, The single port Goes to >>> On the Router, The port thats all by it self
Old 12-29-2010, 07:57 PM
Ok, it aint working.
How it is now...
I have the cable plugged into the cable modem. Then I have an earthnet cable plugged into the cable modem to the pc.
If I connect to the wireless router, from the cable modem (earthnet cable). Then from the wireless router to the computer (earthnet cable), I get nothing. Says I dont have a cable plugged in.
Old 12-29-2010, 08:28 PM
cable to modem
modem to router
router to computer
If using wireless method, and you have a bluetooth card or your computer is pre-loaded with bluetooth, just turn on...........
If it doesn't work, make sure modem is ON
Make sure router is ON
Still not working? Unplug both router and modem for 30 seconds. Then, plug-in modem,,,,,then plug in router. Wait for the lights to settle down and stop blinking.
Go to computer and look for a cable or bluetooth icon in the tool tray and open it, it will tell you to connect........Do it.
Old 12-29-2010, 08:29 PM
If all else fails, call your cable company and they will walk you through it.
