help Catalytic Converter Emissions here - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-19-2013, 03:06 PM Thread Starter
chris-rector's Avatar
Ok i have looked at a few threads and no one has really answered the question So I moved from Texas I live in Centennial Co. now with is Arapaho County. I have a 4 inch exhaust on my 6.0 I dont have a Catalytic Converter on it. So I called a place and they say I have to have one.
I see trucks all day long with 4 and 5 inch exhausts on there trucks so how is it that they are passing emissions with there exhaust?
Also what am I suppose to do put an smaller Catalytic Converter on my truck? Doesn't that defeat the purpose of having a performance exhaust ?
<a href="http://truckprofile.com/members/chris-rector/Ford-F350-2003/694">My Truck Profile</a>
chris-rector is offline
post #2 of 11 Old 09-19-2013, 04:08 PM
Beewoody's Avatar
I bought a magnaflow 49 state legal high flow cat for my 4" exhaust.
Sent from AutoGuide.com App
05 F-250 SD Crew Cab Lariat 6.0 PSD: BPD Oil Cooler, BPD Manual Fan Clutch Adapter with 7.3 fan, Built FICM powerboard w/Atlas 40, Gearhead's SRL, 8k Tow, Unlimited Tune, EGR Delete, Blue Spring Mod, 6.4 Banjo, Updated HPOP/STC, Updated Standpipes/Dummy Plugs, EC-1 ELC Coolant, Updated Turbo oil supply/return lines, Edge CT, 2.5" Readylift Level Stage 3, 35/ 12.5/ 18 TOYO AT2 Extems' mounted on 18" MB wheels and finally.... STOCK HEAD GASKETS
.... 203K miles on 10/3/2014...
Beewoody is offline
post #3 of 11 Old 09-19-2013, 04:31 PM Thread Starter
which part number did you use. If you can remember
post #4 of 11 Old 09-19-2013, 04:35 PM
Beewoody's Avatar
Magnaflow 60011 4" universal diesel cat
Beewoody is offline
post #5 of 11 Old 09-19-2013, 04:41 PM Thread Starter
So did you weld it on or clamp it on
post #6 of 11 Old 09-19-2013, 04:43 PM
Beewoody's Avatar
It's a weld on...
Beewoody is offline
post #7 of 11 Old 09-19-2013, 04:47 PM
Raul@Stealth Automotive's Avatar
if your real good at welding you can cut off the clamps off of your stock cat and widen the whole... then weld that to the new cat so its all bolt on...
Raul@Stealth Automotive is offline
post #8 of 11 Old 09-19-2013, 04:50 PM
Beewoody's Avatar
Yeah I'm not good at welding so I took one of the sections out ( while I was installing BPD oil kit) and had a local welding shop weld it on for me....
Beewoody is offline
post #9 of 11 Old 09-19-2013, 04:58 PM Thread Starter
I can weld good at times but I'll let a professional do it too where did you buy it from and what did it cost you if you don't mind me asking
post #10 of 11 Old 09-19-2013, 05:00 PM
Beewoody's Avatar
I paid $200 on clearance but they are $260 on ebay.
Beewoody is offline
