Colorado Questions - Ford Powerstroke Diesel Forum
Centennial State Powerstrokes Colorado Chapter area of the ORG
post #1 of 10 Old 02-16-2014, 06:20 PM Thread Starter
Colorado Questions
We're going skiing feb 25-mar 3 in crested butte. We will be coming from Texas. Are there any locals that can steer me in the right direction as far as typical road conditions. We usually go to wolf creek in pagosa or Durango and are familiar with the passes. Are there any passes near CB the require chains or sections that the county doesn't tend to very well?
Also, my bride would like to do a snowmobile tour. Can anyone recommend an outfit or advise against any.
Thanks
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #2 of 10 Old 02-18-2014, 04:27 PM Thread Starter
Bump
Brett
post #3 of 10 Old 02-18-2014, 05:09 PM
Gene's Avatar
Quoted: 3 Post(s)
Sounds pretty easy. Monarch pass is the only pass you may be unfamiliar with. All of the roads to the ski resorts are well plowed and maintained. Crested Butte is no exception.
Sorry, but I don't know anything about snowmobile rentals out here.
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #4 of 10 Old 02-18-2014, 05:26 PM
sbluke55's Avatar
Quoted: 628 Post(s)
Garage
All major passes and roads are very well maintained. You should not need chains if you have decent tires and 4x4. I go down there a few times a year but I usually come from up north. I checked the weather and you should have clear sky's. It's been so nice around here that all the roads are dry. Good luck.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 10 Old 02-18-2014, 06:08 PM Thread Starter
Thanks for the info. Got caught with bad weather in the pass going up wolf creek in the past and was just wondering if I needed chains or not. I think I'll hold off. Hoping this late in the season it'll be mild weather.
Brett
post #6 of 10 Old 02-19-2014, 01:12 PM
coassist73's Avatar
Quoted: 17 Post(s)
Brett,
Just fyi, This time of the year is when the south can get hit super hard with snow.
These guys are pretty good.
Action Adventures Snowmobile & ATV Rentals in Crested Butte, Colorado
Jeff
Centennial State Powerstrokes Chapter Historian
2006 Ford F350 6.0 CC Dually Lariat
1996 BMW 750IL V12 Monster
2015 Ram 3500 Crew Cab Long Box Cummins
2012 F650 Reg Cab V10 Tow Truck (work truck) (33,300 miles) 21ft Flatbed.
coassist73 is offline
post #7 of 10 Old 02-19-2014, 01:21 PM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
Road Conditions, Speeds, Travel Times, Traffic Cameras, Live Streaming Traffic Cameras, Road Closures and Road Work Information provided by Intelligent Transportation Systems (ITS) a branch of Colorado Department of Transportation check this for live data/info
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 10 Old 02-19-2014, 01:33 PM Thread Starter
Originally Posted by coassist73 View Post
Brett,
What do you mean south? I'm already way down south by Houston! Any other tips for the weather. Going to run our Texas diesel till I get closer to CO then switch to what I can find there. Planning on gray bottle power service.
That's pretty slick. Thx
Brett
post #9 of 10 Old 02-19-2014, 01:39 PM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
he means the wet mountain range and sand-de de-cristo range er how ever it's spelled. later in winter/early spring is when the tend to get the heavy fast moving storms that can drop 1-3 feet in a night....as far as power service I'd just make sure you have winter blend (not sure if they do that down by you) to help from gelling.
dannanw is offline
post #10 of 10 Old 02-20-2014, 06:28 PM
MacDougall's Avatar
Brett
yea the weather has been great as everyone has said, and just fyi, the grey bottle of power service does nothing for anti-gel, the white bottle does but either way you probably wont need it if you get a winter blend fuel up here
Mike:
2003 F250 CCSB 4X4, 6.0L powerstroke.
-Sinister coolant filter
-Upgraded blue spring
-5" diamond eye exhaust W/ 6" tip
-Edge CS
-SCT tuner W/ vivians looney tune
MacDougall is offline
