Driveline shop in Denver area? - Ford Powerstroke Diesel Forum
Centennial State Powerstrokes Colorado Chapter area of the ORG
Old 02-16-2011, 06:49 AM
Im having trouble eliminating this moderate vibration/shudder at take off with my 2.5 inch lift and traction blocks. We have tried shimming the carrier bearing, which helped but did not completely eliminate the problem. I am thinking that getting a custom 1 piece driveshaft might be the best solution Does anyone have a good driveline shop that they recommend in the Denver area?
Old 02-16-2011, 10:51 AM
none in Denver I know of....sorry. springs yes. I am sure one of the denver guys will chime in.
Old 02-22-2011, 05:08 PM
Unapologetically American
Feedback Score: 4 reviews
There are a few here in Denver, but I haven't tried them out. What speed does it happen? Is you carrier bearing in good shape? Tires balances, and round?
Old 02-22-2011, 05:18 PM
Happens 0-20 mph mostly. Carrier bearing is shimmed 3/4" but still the vibration is there. Tires are balanced.
Im gonna take it to a specific 4x4 driveline shop this week and see what they say.
Old 02-22-2011, 05:23 PM
Rob Rob is offline
I have heard that replacing with a one piece shaft will eliminate the shudder/vibe you are feeling. Id try and work with them to see if the cost is really gonna be worth it, new drive lines aren't cheap.
Old 02-23-2011, 04:18 AM
There's a place on S Broadway that I have always heard was good. Bear frame and axle, give them a try
Let us know what you find out adn what shop you took it to, because I'm sure that someone will need that type of work at some point
Old 02-23-2011, 06:56 PM
Here ya go. They do great stuff with fabbed race drivelines as well!
Rocky Mountain Drive Line Spec in Denver, CO - YellowBot
Old 02-23-2011, 07:09 PM
wow,,,, the sole purpose i got online tonight is because of this EXACT same issue i had for a couple thousand miles and last week my driveline let go, and exited the vehicle....(had to go retrieve it in a field next to highway)... pic to follow soon.
for last three days i have been looking into this issue. ford is not willing to warranty for obvious reasons(carrier bearing shim and lift kit, 4"front/2"rear) however they did provide me with a TSB that says they know of a shudder/vibration issue and sent out a fix for it. what you may not feel stock is magnified with the lift angles on the driveline.
talking to a one of the best shops in Montana i was told that a one piece shaft from steel will have too much 'jump rope' effect, and the only possiblity to get away with a one piece would be an aluminum shaft ($$$)....
the TSB (TSB09-20-5) states that the driveline should have a 3 degree optimal operating angle,,,,,
ANY TECHS PLEASE CHIME IN
Again pics to follow soon
Old 02-23-2011, 07:19 PM
Interesting....
I have heard of the Jump rope effect, but a properly balanced driveshaft should not/would not have this problem. I know of many people running 1 piece driveshafts at 80+ mph with no problems.
Sounds like that shop was just trying to upsell you. Why would a aluminum shaft be smoother than a steel shaft assuming they are both balanced properly?
Old 02-23-2011, 07:24 PM
anything is possible, but he doesn't even do aluminum, so he had nothing to gain,,, what he was saying is that (in my case) a crew cab truck has a massive length between transfercase and pinion. hence the engineers at ford with hundreds of years of combined experience made it a two piece shaft to eleiminate the angles on the u-joints... just what i understand from him anyway... and aluminum is stiffer than steel, hence less jumprope effect...
