CSP current moding - Ford Powerstroke Diesel Forum
Centennial State Powerstrokes Colorado Chapter area of the ORG
Old 04-05-2010, 07:12 PM
CSP current moding
Painting my bumpers black bed linner...
Truck with no front bumper...
Plastic off the front bumper...
Front and rear bumpers primed with self etching primer...
Waiting on the paint to dry then install....
Old 04-06-2010, 04:52 AM
Unapologetically American
Feedback Score: 4 reviews
You're leaving them with just a primer coat on them? I thought I read, Jeff said something about Line-X bumpers
Old 04-06-2010, 05:44 AM
PROUD AMERICAN!!!
Feedback Score: 5 reviews
We finished lining them yesterday. Aaron did most the work himself, I just helped spray the last coats. He should be getting them back on today and then I am sure he is going to post some pics.
Old 04-06-2010, 05:52 AM
Good stuff then, can't wait to see it
Old 04-07-2010, 06:30 PM
Bumpers Done
Here they are....
Next is rolling the rockers....
Old 04-07-2010, 06:36 PM
Looks great Aaron, I checked them out a bit last night too
Old 04-08-2010, 05:47 AM
PROUD AMERICAN!!!
I think you should use the duplicolor on the grill too.
Old 04-08-2010, 05:51 AM
X2 agree black out the grill, it looks good but I aint good enough to make it look as good as yours does.
Old 04-08-2010, 07:21 AM
BGJ BGJ is offline
Wow, Aaron, that turned out nice. Real nice. Thanks for posting it. (looks like your frame horns need a little black on em)I'm just wondering how durable the front will be with the rocks. Please let me know if you see any chips in it. I'm thinking about doing mine. Did you spray the rubber part as well? I painted my grille with the Dupli bed liner, no chips yet but I haven't driven it more than 30 miles lol since I sprayed them.
Old 04-08-2010, 07:35 AM
BGJ BGJ is offline
I did this mod a couple of weeks ago. Lot's of guys are losing their spares. Not only sucks to be W/O one, but you could kill someone when this thing lets go. I believe the weak link to be this part:
The cable goes into this tube where dirt & moisture collects & eventually corrodes & rusts the cable. I weighed my spare tire today, it weighs 79 lbs. In my opinion, thats quite a bit of weight for the system, especially since it is behind the axle. Lot's of inertia hammering on it when we hit bumps.
This is how I improved mine.
First I slid a thick, square flat washer up the cable to squarely contact the factory spring. I then took a 3/4 inch bolt & ran the cable around it between two washers, tightened it up, then I took the ends & used a cable fastener to tie them together.
I then painted the bolt, nuts, & washers & put a heavy amount of grease on the entire cable. Since there is no place for water to collect, I believe this will last longer than I do.
