Anyone use Strokeshop in St Helens, OR - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
post #1 of 4 Old 05-01-2014, 09:34 AM Thread Starter
Hey guys,
Just wondering if anyone has had work done at this shop? Pretty sure my headgaskets are starting to leak. Occasionally I get white smoke on startup that smells like coolant and my degas is puking a little bit. I put a pressure gauge on the cooling system for a few days and it will slowly climb to 16 psi everytime. I'm planning to do the headgasket work myself, but I need someone experienced with 6.0's to check the heads out and resurface/do anything else they need. I would appreciate hearing comments from anyone that's knows this shop or can recommend another shop for this. I'm located in SW Washington about 20 mins from Astoria, OR. Thanks for the Help.
2005 F350 Lariat 4x4 CCLB
Head Studs
EGR Delete
4" MBRP Exhaust
IPR High Flow Coolant Filter
Blue Spring Mod
PHP Ficm Tuner
SCT Tunes
Leveled with 35's
175/stock Injectors w/upgraded solenoids from Warren
KC Stage 2
Leprechan is offline
post #2 of 4 Old 05-01-2014, 09:37 AM
kafleming19's Avatar
Quoted: 767 Post(s)
With where you are located check out vision diesel performance.
12142 Sky Ln NE
Aurora, OR 97002
Kily AKA Lt. Axe
kafleming19 is offline
post #3 of 4 Old 05-18-2014, 04:10 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
X2 for Vision Diesel!
Derek will get you taken care of.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #4 of 4 Old 09-10-2014, 01:45 PM
also check out RDA (ross diesel & automotive) 4 mi up cannan rd. in deer island or.
2000 f-350 ccsb 4x4 srw, banks ram air intake, amsoil lube front to back!
jerry j is offline
