Newbie Monroe/Wa - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
post #1 of 23 Old 03-09-2014, 08:58 PM Thread Starter
Malardman31's Avatar
Newbie Monroe/Wa
In the process of building my 2004 cclb, my motor puked the oil cooler last july, cant afford to take it to a shop so I'm in pretty deep, always been a cummins guy, but $7,500 for a lariat CC is hard to turn down, so far I've been ordering all my stuff from Vision diesel in Or. ARP'S factory mls gaskets,DRP egr delete,blue spring,6.4 banjos,SCT livewire,sinister coolant filter sys,58v FICM,new lifters etc, done all this with cab on, till I figured the motor had to come out to do the lifters.
I know I'm going to run into problems putting this together, and I'm gonna be nervous as F*** turning the key for the first time, but I need help figuring what inj to run? Vision says rebuild mine for $900 155cc stock nozzles IDK? or do I go Warren, injectors? these are a crucial big thing to these 6.0 I am on a budget of about $1,200 whats a good way to go? I did have 3 bad injectors to begin with when I first bought it.
Any help would be great.
Malardman31 is offline
post #2 of 23 Old 03-09-2014, 09:02 PM
kafleming19's Avatar
Quoted: 783 Post(s)
Welcome! Check out this. The CCR place is a good place to chat for help.
It's really easy to join.
Here is what needs to be done to join.
All you have to do is try to stay active in the Chat Thread, try to make Gtg's if you can and put the logo in your sig. Here is the link and how to do it if you don't know how. Towards the top you will see "USER CP" click it. From there you can click "Edit Signature" on the left hand side. From there you can put your name and what ever info you like about your truck and also add this link to it using the insert image button.
-http://www.powerstroke.org/forum/signaturepics/sigpic138659_2.gif-
Just take a look at some of our signatures to get an idea of what you would like to do.
Also, our chapter director/president (ELi aka Six0~Stroker aka butterfly) might ask you for an internal organ depending on what he is in need for at that time... jk!!!
Here is a place some of us have posted about our trucks and ourselves. CCR Truck/Member Pictures
I think I covered it all.
Kily AKA Lt. Axe
kafleming19 is offline
post #3 of 23 Old 03-09-2014, 09:18 PM
Quoted: 384 Post(s)
Feedback Score: 5 reviews
I would go with Warren Diesel
Derek at Vision Diesel is a gear guy.
You also have a diesel tech with a shop in your town. His name is Toren and he is the owner of Ranaway Diesel in Monroe, Wa. He is active in the CCR chat and will be able to help you with ALL of your issues and work to the 6.0
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 23 Old 03-09-2014, 10:05 PM Thread Starter
Derek has been very good to talk with, but Ive personally had bad experiences w/ DDP in the past, and seen, well it used to be called Evergreen now Pacific, would rather do it myself which I am, Ive never heard of Ranaway.
what would you do for injectors with Warren? I'm going to go w? Innov, custom tunes, 155cc with 30% or just 155? should I rebuild mine?
2004 CCLB, Lariat, 6" lift, 37" Swamper Radials got super cheap!, Ranch hand rear bumper, Ranch hand front brush guard, Diamond eye 5" exhaust, EGR delete, ARP'S, Warren 175's, SCT livewire TS, Innovative tunes, Sinister coolant filter and thermo neck, AFE intake, Blue spring, 6.4 banjos, CAT ELC-1
post #5 of 23 Old 03-10-2014, 05:32 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
I was just in Monroe last night... I thought they were going to close 203 at one point with the water breaching the road...
Ranaway Diesel is in Duvall on 203, across the street from Subway.
Toren is a really great guy and is VERY VERY knowledgeable when it comes to our engines.
Derek and Curtis at VDP are also good guys.
Just steer clear of those other places in your area...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 23 Old 03-10-2014, 06:30 AM
6.0Stroker's Avatar
Quoted: 957 Post(s)
Welcome to the site. I just sent my injectors to Warren last week, we will see how it goes. Biggest issue is he is short on cores so I sent mine in, which takes a little while to get em back.
Unless you plan on building the motor a lot... I would suggest going with a 155/stock nozzle injector.
ask Eli what happens to your tranny when you go overboard and then don't treat it good.. (pickup tranny that is.... don't ask him about his "chiropractor" that's still in debate)
MIKE "HOSS" THOMAS
'03 F350 6.0 6-speed
~EGR Delete~Ported Intake Manifold~4in Diamond Eye Dual Exhuast~Blue Spring~50MM Turbosmart BOV~PMM Coolant Filter~
~155/stock Warren Injectors~Terminator Engineering T500 HPOP~SouthBend Dual Disc Clutch~RCD Stg 2 Camshaft~
~'03 Nighthawk turbo w/Wicked Wheel2
~Rebuilt and Studded by Toren~
6.0Stroker is offline
post #7 of 23 Old 03-10-2014, 05:51 PM Thread Starter
I really dont plan on going mod crazy, Id'e like about 400-430 RWHP will the stock tranny handle that, I'm not going drag racing or pullin, just a little fun once in awhile, the shop in Monroe I was at today told me SCT is S### told me to do a banks programmer ? idk what to get anymore, I'm not in a hurry but would like to buy the right stuff one time, and learn from everbody elses trial and error, I really like the SCT TS other people say get the Edge cts? and the sct X3 idk
post #8 of 23 Old 03-10-2014, 06:24 PM
Quoted: 783 Post(s)
SCT is the only way to go!!! None of the other tuners tune your transmission and you cant get customized tunes. With an SCT I think you will be around the mark you want to be at. A lot of guys on here including me run the SCT on stock trucks all day long with no problems. Everyone on here will tell you to go SCT.
That other shop probably gets a kickback from banks and thats why they pushed it.
Kily AKA Lt. Axe
post #9 of 23 Old 03-10-2014, 07:24 PM
nordstrom's Avatar
Quoted: 2 Post(s)
Welcome to the CCR, my name is Jason I currently live in Marysville/Lk Stevens area. I grew up in Monroe and my whole family still lives their. Toren is a great resource for you and knows what he is talking about. I had Dynomite do all my work (studs, heads, BPD, bed plate, and everything else) 2 yrs ago along with Matt (matty834) with so far good results. My customer service was fantastic but Matts wasn't as good. I will most likely be hosting a wrench day sometime this spring. Matt lives in Granite Falls & Dennis is in North Bend. Glad to have ya, don't hesitate to reach out if you need help
2006 F350, Holders Ported Intake, ARP Studs, Factory Turbo w/MTW Billet Wheel, Edge Insight, Atlas 40 FICM Tune, Stock Sticks, BPD Ficm 53V, BPD EGR Cooler, BPD Remote Oil Cooler W/ cold weather pkg, BPD Water Pump, Blue Spring Upgrade, S&B Cold Air Intake, CCV Relocate, 64K miles and counting
nordstrom is offline
post #10 of 23 Old 03-15-2014, 08:25 AM Thread Starter
Well sent my injectors back to Warren yesterday, they talked me into 175cc stock, plus the $400 for the thing they do to help prevent stiction, also get a 1yr warranty that way, getting excited to see how this thing is gonna run.
