Newbie from Edmonds - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
post #1 of 15 Old 01-09-2014, 08:57 AM Thread Starter
Newbie from Edmonds
Not new to Fords, but new to the diesel side of life. Previously had an '02 & an '11 F150. Now have this '04 CCSB, OASIS report stated that the engine was replaced 47k ago. This is my DD and be used to tow our '08 Outback 21rs.
Will keep this basically stock, when funds allow will be buying a front hitch to put my 9500# warn on it, and when thats not there and towing the trailer a bike rack.
2004 F350 CCSB
2008 Outback 21rs
wa_psd77 is offline
post #2 of 15 Old 01-11-2014, 05:57 PM
Sandaholic's Avatar
Not sure what all you get into, but if you're going to possibly use that winch to say get unstuck in the woods you might want to think about getting a heavier unit. A 9500 will work in some situations but will definitely be lacking if push comes to shove.
Welcome to the forum from a non stroker
Roy
05' Cummins,4x4,NV5600, bunch of bolt-ons
<<<Link
,6" Atlas leafs &
,<<<Link
<<<Link
647/1180 12.861@107.39 7700lb race weight
Sandaholic is offline
post #3 of 15 Old 01-12-2014, 08:56 AM Thread Starter
Thanks for the welcome. The winch is mainly used to pull trees off the road to our cabin in the woods and to pull people out of the sand at the beach.
2004 F350 CCSB
2008 Outback 21rs
wa_psd77 is offline
post #4 of 15 Old 01-12-2014, 09:18 AM
7.34ever's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Good morning and welcome to the .org.
If you are interested in being a CCR member it's easy.....add the CCR logo in your sig(someone will help with that. I suck at it. lol), be active in the chat thread when you can, and try to attend g2gs near you. That's it!
If that motor only has 47k on it and the h/gs are still good you may want to look into deleting the egr asap so you don't have a melt down. I don't want to scare you but getting rid of the egr would be the best thing you could do for the truck especially if you intend to tow with it. I also recommend some monitoring of some kind.
12TH Man
Live in WA or OR??? Check out these links.
7.34ever is offline
post #5 of 15 Old 01-12-2014, 09:21 AM
7.34ever's Avatar
Quoted: 2 Post(s)
Here's the link to the chat thread. CCR Chat Thread
If you have any problems navigating the forum don't hesitate to ask.
12TH Man
7.34ever is offline
post #6 of 15 Old 01-12-2014, 04:15 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1668 Post(s)
Feedback Score: 4 reviews
Welcome to the Org
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #7 of 15 Old 01-13-2014, 09:43 AM Thread Starter
I took the truck in to get the Oil, filters and fuel filters changed and asked the owner about the truck to learn a bit about the faults of the 6.0. He has an '05 with +200k on it and stated as long as I don't mess with it (adding tunes, etc.) and kept up on maintenance, it should last me a good long time. I then asked about adding a coolant filter and doing the EGR delete and he said to only do the coolant filter.
I took it to Pacific Diesel in Monroe, WA since the truck had some maintenance done there previously (different company name at the time).
2004 F350 CCSB
2008 Outback 21rs
wa_psd77 is offline
post #8 of 15 Old 01-13-2014, 10:01 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Welcome!
It's really easy to join.
Here is what needs to be done to join.
All you have to do is try to stay active in the Chat Thread, try to make Gtg's if you can and put the logo in your sig.
Here is the link and how to do it if you don't know how.
Towards the top you will see "USER CP" click it.
From there you can click "Edit Signature" on the left hand side.
From there you can put your name and what ever info you like about your truck and also add this link to it using the insert image button.
-http://www.powerstroke.org/forum/signaturepics/sigpic138659_2.gif-
Just take a look at some of our signatures to get an idea of what you would like to do.
Here is a place some of us have posted about our trucks and ourselves. CCR Truck/Member Pictures
I think I covered it all.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #9 of 15 Old 01-13-2014, 06:58 PM
7.34ever's Avatar
Quoted: 2 Post(s)
It will last longer with consistent maintenance, yes. It will last longer without tunes, yes. The h/gs WILL ABSOLUTELY last longer if the egr system is gone, yes. #1 cause of h/g failure in a 6oh. If funds permit you should monitor it so you can keep up with what is happening in there. Post up in the chat and talk to some of the boys about 6oh issues. You'll hear enough. lol
12TH Man
7.34ever is offline
post #10 of 15 Old 01-13-2014, 11:03 PM
jeffstr57's Avatar
Welcome to CCR!
2013 Ford F350 Lariat FX4 6.7L
jeffstr57 is offline
